Couple issues with CK 3510 se HST
   / Couple issues with CK 3510 se HST #1
MYOLFarm
none yet
Just noticed 2 coolant leaks, one right at the top radiator neck/hose area and one on bottom of motor where a rubber line connects to a hard line. Both have hose clamps and seem to be tight, tried tightning a little with no difference, anyone seen this? Also when going up my drive way I run in second gear, when putting a load on tractor it will pop out of gear into neutral, not every time but frequently, any thoughts on this ? It is about a1 1/2 years old with 100 hrs, what does the warranty cover?
   / Couple issues with CK 3510 se HST #2
You'll have to contact your dealer or check the Kioti website to learn what the warranty covers. Given the age of your tractor all your issues should probably be covered.
   / Couple issues with CK 3510 se HST #3
I agree check with your dealer, those items should be covered.
   / Couple issues with CK 3510 se HST #4
Is this where one of your leaks is? Mine just got picked up today for the coolant leak, I tried tightening the clamp as well as replacing it.
   / Couple issues with CK 3510 se HST #5
Not sure why the image didn't attach, lets try that again.
2000 JLG 600AJ ARTICULATING LIFT (A55745)
2000 JLG 600AJ...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2014 Ford F-250 Ext. Cab Pickup Truck (A54814)
2014 Ford F-250...
2015 FORREST RIVER CHEROKEE (A55745)
2015 FORREST RIVER...
NEW Thiessen Track Closer Disk (A57024)
NEW Thiessen Track...
