County Road Easement Cleanup
/ County Road Easement Cleanup #21
That looks like power line clearing, not road clearing.
Wish I had a “before” picture of when I bought my property, where electric ROW trimmers left a huge mess of cut trees everywhere. I have since cleared it out and keep it mowed. ROW trimmers cut a locust tree down a couple years ago that didn’t need cut, left it laying in my creek. They also cut this huge tree that was across the road from power lines, had nothing wrong with it, but left a dead tree that eventually fell and snapped a pole as it took out the power lines.
/ County Road Easement Cleanup #22
Pioneer Electric is putting new power poles in along my road. They have done an excellent job. They keep me informed, left me keep the trees I wanted that they cut and said I could have the old poles if I wanted some.
Cleaned the area in the right of way well. No complaints, really could not be happier. Wish it was the same in your situation.
/ County Road Easement Cleanup #23
I wish I could keep them out except with permission. But this particular property is roughly 100 acres with multiple entrances. None of which I can see from the main house. They just come on the property whenever they want.
They *do* have a legal right of way to maintain the power lines. But it's only a few feet to either side of the lines-- just a narrow strip through the property.
I can play hardball by not letting them have any access except their tiny narrow strip. Which is darned inconvenient on them. But they can respond by refusing to do any post-trimming cleanup, saying "we can't get our truck in here ...."
I guess I was confused. Your profile shows that you own 2.5 acres. That must be wrong because now you're saying you own roughly 100 acres with a power line running through it. I guess that's one of the disadvantages of a power line on your property.
/ County Road Easement Cleanup #24
We have PECO replacing a lot of poles in the area, so being proactive.
Unfortunately, they can't do anything about tall dead ash trees not near the lines.
getting short power outages every month from falling trees.
70-90 foot Ash tree meets pole or line, pole or line lose every time.
They did come through today, 2 guys with shovels and a dump truck to get all the rocks and debris out of the road from yesterdays flooding.
/ County Road Easement Cleanup #25
You were correct, but we own multiple properties. The larger property, in CA, is served by PG&E.
btw, I have found "official" PG&E employees to always be polite, professional, and responsible. But they don't do any of the actual work that occurs on my property. PG&E sub-contracts to perform inspections and identify trees to remove or trim, and sub-contracts with different companies to perform tree work. The communication between those companies has historically been terrible if they communicate at all.
Finally, a year ago I was told the largest PG&E tree trim/removal contractor "bought" the contract from the primary company that inspects and decides which trees to trim or remove. That seems like a huge conflict of interest-- the more trees they mark for trimming and removal, the more money they make.
/ County Road Easement Cleanup #26
Thanks for the kind thoughts. I hope circumstances improve with time. Being sued for multi-billions, and losing, has caused a great upset all up and down the entire utility-- touching everyone.
/ County Road Easement Cleanup #27
In my area both county and utility crews do such work. On no schedule and NEVER with notice, they bring equipment, chainsaws, and chippers and start removing every possible thing they think they can get away with.
6 months ago an entire vegetation barrier along side a road was cut and chipped. It was no threat to traffic or power lines-- yet they obliterated it. The county says "we can cut whatever we want back to your fence line." But if there is no fence-- they act as if there is no limit.
A utility crew took out an entire line of trees near power lines-- up to 12" diameter oaks. No notice. When I discovered that later, I asked: "what happened to the oaks?" Answer: into the chipper. So there went good firewood and most they should not have cut anyway. But they were gone. Complaining after the fact is a total waste of time because none of the officials or supervisors care.
The utility crews here don't respect private property and seem to believe they can do whatever they want. A few years ago a crew let themselves through a locked gate and was driving a heavy truck through my pasture while it was being flood irrigated. They were indignant that I told them to get out of the pasture and back on the road. After that I removed all "utility locks" from my gates.
I have complained to officials, removed locks, put up signs, and informed supervisors their workers cannot be on my property unless they remain within the legal utility easement and right of way. Of course, in their eyes, I am now a "problem homeowner."
If they call to arrange access, I try to accommodate. But if they do even call, which is rare, it is usually a call something like this: "We're at your front gate right now, can you open it so we can get through?"
Crews came to our house, and had the gall to ask us if we mind them coming in this coming month to work on our hydro lines, put a couple poles in. HEck, they even used our driveway turnaround when we gave them permission to do it. I was horrified that they did their job so efficiently and politely, taking out the precious Alders in the process... and even repairing my driveway better than it was. Made me so mad.
/ County Road Easement Cleanup #28
My county does that, probably to keep fire danger down. I'm actually looking at having that done to my drainage ditches, drainage pond surround and blackberries thickets by a contractor. They say it will all be mulched down to the ground and I can then use my compact tractor and brush hog to keep it under control. They use a flail mower similar to what is shown in the picture. I'm all for defensible space as we had to evacuate last year due to wildfire. Was glad we had a house to come back to.
/ County Road Easement Cleanup #29
Hugs and kisses to FPL, Florida Power and Light, they take tree trimming seriously. Mostly they use Asplundt Tree Services for the main line trimming but even the small contractors they use for the trees on private property do a good job.
/ County Road Easement Cleanup #30
Our County mows the right of way a couple times a year. I keep mine mowed every time I mow the lawn. I like it looking neat an tidy.
Accross the street is a farm field (row crops). I keep the ROW mowed there too so I don't have to look at the scraggly weeds. Tried to talk the farmer into tilling it up and letting me plant grass. He did not want to get that close to the road or the poles. My tiller is too wide it would take out part of his planted field. Spraying 24D or something also will be a no go over there. So I just keep it mowed down so I do not have to look at the ugly weeds.
/ County Road Easement Cleanup #31
I have empathy for your situation. I have 6 pipelines through my place ... started with 4 when I bought 25 years ago. I don't know if I can suggest anything to help you, but I can tell you about my experiences.
When I bought I was naive. They owned a ROW and I didn't understand their limits or what I was supposed to put up with. BTW, ROW is only paid at the time of installation - nothing annually. They would come and dig up my pasture for repairs. They took advantage, but are now sitting up and paying attention to me and even calling ahead of time. Out of my frustration, it all changed when I sent a "nice" letter demanding compensation for damages that they caused. The more I did it, the more comfortable I felt putting healthy numbers on a list of damage issues. I itemize everything I can - its my grazing pasture. No grass means dirt and nothing for cattle to eat. Sure, it's a relatively small area, but I list what it would take to return it back to the way it should be. Leveling, seed, water, fertilizer, re-leveling after a couple of years of settling, more seed, water, fertilizer. Takes 3 years to get it back. Once I took pictures of them using my pasture for a parking lot - 100 feet off of their ROW because that is where the shade was. I even found and photographed poop piles and paper towels because they didn't have a Portapotty, so I charged for that too - by the day. I charged for equipment stored on my place after the job was finished. You name it, I listed and charged. Photos are golden. Rarely do they challenge the invoice.
A quick update. They had lunch last Friday in my driveway when I returned home from running some errands. Their pickup had a magnetic sign on that said "Contractors for inland Power."
Being friendly, I pulled my pickup next to them, two people in the cab. They rolled down their window and here is roughly the conversation I had with them:
Me: "Hi! How's it going?"
Them: "Great! Going well. Almost done."
M: "Where are you stopping?"
T: "Just a bit further, need to stop for lunch break, otherwise we would have finished already."
M: "Oh, gotcha. I see you work for Inland?"
T: "Operators Union, hired out by Inland, yes."
M: Just clearing brush and trees along the powerlines?"
T: "Yep."
M: "Well, it looks great! That flail does a hellova job!"
T: "yes it does!"
M: "Well, I'll let ya get back to your lunch. Thank you for sharing, have a great day!"
T: "Yep, you too!"
And I drove up to my house.
The trees do pose a problem with the powerlines, and they come and drop some when either they see them leaning or dying that might threaten the lines, or they come out when I see them. Typically, and has only happened twice since living there, they show up and simply fall the trees into my property. If I can get to them easily, I buck them up for firewood.
I was just amazed that they would come out for the brush. The lines are really far away from the brush, but I'm not complaining. Least now I know exactly where to put the t-post fence along the road!
/ County Road Easement Cleanup #33
It’s been about 15 years ago but a tree on my property fell on the power line and broke it during an ice storm. If you had gone out there beforehand you would have picked 20 different trees that would have been a problem first. They can be pretty far away and still cause a problem.
/ County Road Easement Cleanup #34
That's a sweet looking setup!
Local power company has come through my property twice on the 7 years I have owned it to clear around the lines.
Never again, they have absolutely butchered the task and made the lines no better while making the property look like garbage.
This past winter they came through and cleared small brush by hand. Being that we had 2ft of snow on the ground it now looks like I have some sort of medieval barricade in front of my house. The stumps are 2 ft tall and most slant cut, perfect for someone to impale themselves on.
They left anything that was larger and clearly rotted that lean to the lines, yet cut stuff 20 feet away from the lines if it made their walk easier back to the road.
They do ask....and the answer will always be a no from now on. The work does nothing to help keep the power from going out, at least on my property.
1993 Transcraft DTL140W2 38Ft 60 Ton Spread Axle Step Deck T/A Trailer (A64194)
1993 Transcraft...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
2007 Ford E-250 Cargo Van (A64556)
2007 Ford E-250...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2012 Kenworth T300 17ft. Cab and Chassis Truck (A64194)
2012 Kenworth T300...
