Loader Counterweight for 5075E
/ Counterweight for 5075E #1
cangiupsuatractor
trenton, nc
John deere 5103, 5075E
I have a new john deere 5075E and now looking to add counterweight in the front (windrow machine is attached in the back). Need help finding part number for counterweight and also parts that support this counterweight. I really appreciated any help.
Sincerely yours,
Andrew
/ Counterweight for 5075E #2
You could add 370 lbs of weight to the front just by loading the front tires with rim-guard. That might be easier then adding the weight rack and " Quick-tatch" suitcase weights to the front. Not as easy to take off when not needed though.
/ Counterweight for 5075E #3
The weight bracket is L58783. It weighs 146 pounds. You will need 2 of R52924 bolts and 2 of 19H3210 bolts to attach the bracket to the tractor. The individual weights are part number R127764. They are about 100 pounds each. You need to install at least 2 since they have to be bolted together to stay on the weight bracket.
/ Counterweight for 5075E #4
I would go with the front weight bracket and suitcase weights as required. The front weight bracket makes a great front bumper and could save your grill/hood from damage
/ Counterweight for 5075E #5
Reviving an old thread.
I too am looking for a 5075E weight bracket.
Does anybody know what the difference is between the L58783 weight bracket and what the R269727 weight front support (100 lb) that are offered on JD Parts?
John Deere - Parts Catalog
I see the R269727 weight front support is held on to ____(what?) by 2 bolts, whereas the L58783 weight bracket looks like it matches the 4 bolt holes on the front of 5E series.
I assume the L58783 is what I want, but what is the R269727 weight front support?
Price-wise the L58783 weight bracket is cheaper than the R269727 weight front support.
I also see a part number AR124753 on the internet that says its a weight bracket for the 5075E??
2009 INTERNATIONAL 7600 6X4 T/A  VACUUM TRUCK (A66091)
2009 INTERNATIONAL...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
2017 Crane Carrier Co. T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
PT 4'x15' Single Axle Ladder Trailer (A64912)
PT 4'x15' Single...
SDlanch SDLGC8 Electric Golf Cart (A64912)
SDlanch SDLGC8...
