Cost to weld hooks & clevis on FEL
   / Cost to weld hooks & clevis on FEL #1
Hoffie
Southcentral Pa
Kiota CK25
What should it cost to have 2 hooks and a clevis welded on a FIL? I supplied the hardware.
   / Cost to weld hooks & clevis on FEL #2
Those an a LONG piece of angle for additional support costs me a case of Corona's...:D
   / Cost to weld hooks & clevis on FEL #3
Shouldn't be too much. Nothing outrageous at all. I'd say if you can catch a welder on a job with a service truck or a local machine shop with the doors open and an empty shop, or a buddy..... should be reasonable of US$25 - US$50 maybe????
A case of Corona is about US$25.00 or less...
   / Cost to weld hooks & clevis on FEL #4
What did they quote you?
A used stick welder is pretty cheap.
I had a $40 quote. It includes welding plates on first then adding the hooks and clevis.
   / Cost to weld hooks & clevis on FEL #6
Sounds OK to me.
   / Cost to weld hooks & clevis on FEL #7
Cost has a high range. Some shops will just do it and send you on your way. The shop gets a long term customer and they don't have to do a bunch of paper work that probably costs them as much as the job!
Other shops may charge you for an hour of time. Assuming you bring the machine or bucket to them
If you want to minimize costs and have a good result, strip off the paint from the area you want the hooks and any supports added. Then clean up and repaint after it's attached.
For me, getting the stuff to a shop is about an hour's work each direction. It was cheaper to get a 255 amp mig welder. (That's my story and I'm sticking to it!!)
jb
   / Cost to weld hooks & clevis on FEL #8
sounds cheap to me
   / Cost to weld hooks & clevis on FEL #9
A reasonable quote. I don't think you are getting ripped off, if that is your concern.
   / Cost to weld hooks & clevis on FEL #10
My dealer welded them on for free when I bought the tractor.
Now if you look through my posts, you will observe that I have a high opinion of the dealer - but that is only one small reason.
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
Kivel Pallet Forks (A47384)
Kivel Pallet Forks...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
M & M 5 Bottom Plow (A50515)
M & M 5 Bottom...
