Cost to connect to the grid?
   / Cost to connect to the grid?
The 3 contractors from our area evaluated the site and gave us ridiculous quotes in the end. Not sure if they are so busy and they can afford to refuse work by presenting astronomical quotes or really those are their rates. I extended my search in finding a contractor at 150Km away and surprisingly I found one at half of the cost. Just for reference, a hydro pole 45ft was quoted between $1800 and $4200 and the wire between poles at $2.5 to $6.
   / Cost to connect to the grid? #62
Back in the 80s I worked on a few underground projects that included water mains and power lines through towns, out in the country, and in new subdivisions. This was all over Central California. Because of earthquakes, and rocky soil, the requirement was for at least a foot of sand to be all around anything buried in the ground. Most trenches where 3 feet wide, and the hardest part of the job was getting the sand in the ditch all leveled off for the pipes. I never saw anybody pull wire through the conduit, so I don't know how involved that was, I was just there for the installing of the pipe/conduit, and then filling in the trenches. Knowing how many people where involved in these jobs, and what it costs to move equipment to those locations, and how ridiculous insurance was back then, I would think that going overhead would be a lot cheaper then underground. Something to consider is how big the conduit has to be for high voltage. Not the service line to the building after the meter, but the line going to the transformer, where the voltage is reduced.
When I ran power to my place 20 years ago, I was told to provide a list of how much "load" I was going to use. The more power I was going to use, the lower the cost for the install. My line was close to 2,000 feet. It crossed a State Highway, and then came down the Highway before entering my land. My neighbor allowed the power line to run inside his property line, so there wasn't any issues with the Highway officials.
Because I put in a 1,200 amp meter, they did all of it for free. I had to pay for the breaker box, which holds six 200 amp breakers. It had to be mounted on a concrete pad, which I did myself. I hired an electrician to connect the meter to the breaker box, which was around $200 for about two hours of work. After the breaker box, I did everything myself with direct bury lines to my buildings.
In my experience, asking the Power Company for the best way to do this is what saved me a bunch of money. They where very helpful, and went out of their way to work with me. As a remodel contractor, I've had a few dealings with 3 different electric utilities in my area, including a co-op. In every case, they have all been very helpful at getting new power to where it was needed. The client would make the phone call, somebody would come out, we would all get together and talk about what was needed, and they guy from the power company would put together a plan to make it happen. We just let them do their thing, their way.
The one time that I had a problem that was at my place, I had to contact the State Commission to get it resolved. I forget who that was, but once I contacted them, it was taken care of quickly.
If you are struggling to get anything done, I would consider contacting the government agency that overseas the power company in your area. Not to complain, or cause trouble, but to ask for help and guidance. It can't hurt, and sometimes you might be surprised at what you find out.
   / Cost to connect to the grid? #63
Just installed two 40' utility poles, cost per pole was $1125.00 US Dollars.
Previous job was 25' utility poles, cost per pole was $300.00 US Dollars.
The larger diameter poles (taller Poles) have always cost more by about this proportion.
If the codes allow shorter poles (lower conductor spans), it is always cheaper to install more shorter poles to run the conductors on versus the taller poles.
I am retired, LOL!:unsure:
But not afraid to work for food.:)
   / Cost to connect to the grid? #64
Wow crazy prices , When we built our cabin 20 yrs ago it was 2200 ft from the road , The local co-op charged 4500 dollars and we got free electricity until the 4500 was used up.
   / Cost to connect to the grid? #65
Tesla Power Walls require a full time internet connection to work. I find if you live in a location where off-grid sounds like a good option your internet connection is sketchy. There are spots on Hwy 6 between Mount Forest and Owen Sound where my Rogers cell phone has zero service. Canada pays the highest internet and cellular prices in the world but has sub-third world service outside the GTA.
I've got Enphase batteries (LiFePO4); they don't need to be grid-connected (I've got a microgrid setup; the solar & batteries are usable regardless of grid status).
I don't "have internet" (I WFH and read TBN via my cellphone's hotspot, previously had a local company's broadband wifi but tree growth killed that, and T1 before that, starband - not starlink - before that) but the enphase system uses its own crappy cell connection (VZW works here, but enphase apparently contracts with ATT which doesn't work well around here - but it works just enough) to do cloud statistics and system updates.
The actual operation doesn't require any network connection, but I don't think they'll let you provision a system without at least cellular data connection.
   / Cost to connect to the grid? #66
When I developed my first property, a 400 amp service was free, except I had to dig the trench and install a 400 amp panel.
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A55788)
2019 Ford F-350...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A55787)
2019 John Deere...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A55787)
2017 Kawasaki Mule...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
