Cost for a cement slab foundation
   / Cost for a cement slab foundation #11
Just got about 5 bids in central Texas and it ran 3.79 to 8.75 a foot for a 4" slab.
Thanks for the responses everyone. The reason I asked is that a barn builder gave me a price with and without him doing the floor. His price for the floor was $11.50/square foot!! /forums/images/graemlins/shocked.gif
I'm calling around for prices.
   / Cost for a cement slab foundation #13
WOW!
My 30'x40'x4" slab INCLUDING the barn turn key installed is less than that!
$13,360 / 1,200 sqft = $11.13 sq/ft!
I hadn't realized how blessed we were in this area on how cheap it is to build things.
   / Cost for a cement slab foundation #14
Last June I had a 24'x42' slab poured for my steel pole garage/workshop. Slab: 6" thick, 3000 psi concrete, #4 rebar criss crossed on 24" centers, footings 12" wide x18" deep.
Cost: $7500.
   / Cost for a cement slab foundation #15
I am planning for a post-tension foundation with beams about 20" deep and main thickness 4" and the price is somewhere in the $4.75 to $5 per square foot range, turnkey. This does not include piers to be drilled under the slab.
I just got a quote from a local contractor:
4" stone, 4" concrete, 6x6 10/10 wire, 6 mil vapor barrier is $4/sq ft. If I made the concrete 5" thick his price would be $4.45/sq ft.
That's a little better than $11.50/sq ft quoted by the barn builder! /forums/images/graemlins/ooo.gif
Now I just need to find a good barn builder with a decent price.....
   / Cost for a cement slab foundation #17
I charge ~5.00/sf w/ 1/2" bar in a 2-3' grid not including stone underneath.
Do not use mesh wire. Use rebar and fibre crete. I have used this combination for 10+ years and have never had any problems.
   / Cost for a cement slab foundation #18
I second this. Every slab I have ever seen poured with the 6-6-10 mesh cracked in a short time. The ones done with rebar do not crack as often, that is not to say they won't crack if poorly done, but properly prepared they are much better. #4 rebar (1/2 inch) on 2' centers
2" of sand on top of the vapor barrier is called out by most engineers. Again, it helps prevent cracking.
   / Cost for a cement slab foundation #19
The sand lets the slab move as it expands or contracts.
Egon /forums/images/graemlins/grin.gif
   / Cost for a cement slab foundation #20
Wire is actually stronger than rebar, but it's extremely dificult to keep in the middle of the pour. What happens is it ends up at the bottom of your slab and provides nothing to the strength of the cement.
Rebar is allot easier to keep in the middle of the pad.
Eddie
New Holland 273 Square Baler (A50774)
New Holland 273...
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2017 Nissan Sentra (A50324)
2017 Nissan Sentra...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
