Spreader Cosmo 500 spreader
/ Cosmo 500 spreader #11
Since I have a cab I can not operate the lever from the seat.
I just trun the PTO on and off and thats usually good enough to stop the bulk of the flow.
Fred
/ Cosmo 500 spreader #12
I hitched a COSMO500 spreader to my tractor and the flow lever bashed out the tail light lens. Need to TIG an extension lever AWAY from tail lamp. Assume lever faces tractor to adjust flow while driving. else pours as you run like fool for driver seat. better to drive tractor THEN pull chute open. Notice seed lever too tight must loosen/grease BEFORE operate. why they ship in that condition.
/ Cosmo 500 spreader #13
I put one of them COSMO 500 spreaders on my tractor last night but the seed lever bashed the balls out of my tail light. That calls for an extension lever modification to a different location. Goes without saying, THIS lever faces the tractor so I can adjust the flow while driving, and if not, then it pours out as I make a run for the driver seat and bang my balls into the shift-stick. So now, I prefer to drive the tractor, and THEN pull the seed chute open, that's if I can reach it without throwing my back out again, my wife said honey your seed lever is too tight and in your rear and you should loosen your nut and grease your lever BEFORE you get into position.
/ Cosmo 500 spreader #14
I guess on some tractors (compacts) the lever could contact the fender area... I have mounted COSMO spreaders to numerous different tractor models and never had the problem.....the adjustments, slides, etc were assembled by dealer....they probably didnt adjust properly....machines are shipped from Italy and dealer-distributor assembles here.
/ Cosmo 500 spreader #15
Greenbeans welcome to TBN...
I'm impressed that you searched and found a FOUR YEAR OLD thread related to the Cosmo 500 spreader to add to...rather than starting another thread...:D
Hopefully someone will have an answer for you...:rolleyes:
/ Cosmo 500 spreader #16
I love old threads,, especially when im looking up equipment that i may be purchasing,,, i get to use all your combined knowledge towards my decision to purchase or not, and i get to see the faults associated with that item.
John Deere 270A (A60462)
John Deere 270A...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
