Correct Type of Engine and Hyd Fluid
   / Correct Type of Engine and Hyd Fluid #1
8N_John
Kearney, Missouri
1952 Ford 8N
See photo of Hyd Fluid and Engine Oil I put in my 8N. I'm a beginner, so before I run the tractor much with these new fluids, I want to make sure I put in the right stuff.
Engine Oil- I put in 30W oil as most people have recommended, but am not sure if it's detergent or non-detergent from the bottle. I assumed it was detergent, but now I'm not sure. Is Rotella detergent oil?
Hyd Oil- The stuff in the photo seemed to be the closest I could find to what people recommended. Is this good stuff or should I go with something else?
   / Correct Type of Engine and Hyd Fluid #2
I have one question. Is ur tractor brand new? cause if it is u should wait a bit before using rotella oil. The exact hours i'm not sure. I use rotella for my kubota but i'm the second honor. For the hydraulic fluid....thats very close to the stuff we use on our rough terrain forklifts at work...which see more hours in a year than most machines see in a life time. We have one that has over 25 000 hours on it...all of it a hard life...although all hydraulics had to be redone at about 12 000. engine is still all original..sure dont build them like they used too
My tractor is a 1952 8N. I just bought it. Do you know if Rotella is detergent oil?
   / Correct Type of Engine and Hyd Fluid #4
that is the one thing i do not know. I can try and find out for you though
   / Correct Type of Engine and Hyd Fluid #5
Ok i've done some reading on the rotella site. Now if u mean by a "detergent oil" that it contains detergents then it does. But apparently it says all oils contain detergents. Now this could all just be bull to try and sell their product, but aparently they use an all calcium detergent as apposed to the magnesium detergents found in most other brands which tends to cause more damage over time. Hope thats what you meant. If not let me know i'll see if i can figure something out for yah
   / Correct Type of Engine and Hyd Fluid #6
What is the EP rating on that hytran oil. It looks like it is a 90wt oil.. which is about right. However, look it over.. Ideally it should be gl-1 as gl-4 and 5 may have too many sulfur compounds which may not be kind to yellow metal.
Post back.
Soundguy
   / Correct Type of Engine and Hyd Fluid #7
I always use Pennzoil 30W in both of my 8N's and never had any oil consumption problems. It is a deteregent oil.
90 WT gear lube for the hydraulics, generic 5 gallon cans.
8N's are wonderful machines. Heaven knows how many of them are still working today and they quit building them about 1952.
Search on "Ford 8N " and you will find hundreds of links for 8N sites.
Bill Tolle
   / Correct Type of Engine and Hyd Fluid #8
</font><font color="blue" class="small">( I have one question. Is ur tractor brand new? cause if it is u should wait a bit before using rotella oil. The exact hours i'm not sure. I use rotella for my kubota but i'm the second honor. )</font>
Andre - Why should Rotella NOT be used on a new Tractor?
I am about ready to perform the 50 hour service on my B7610 and was planning on using Rotella 15W-40. Now I'm wondering if I should?
   / Correct Type of Engine and Hyd Fluid #9
OOps forgot to say the synthetic...sorry i use synthetic in mine so u cant start off using synthetic oil on a brand new tractor. Has to be broken in first. I dont believe this oil is synthetic though..dont know for sure
16FT Flatbed Truck Body (A52377)
16FT Flatbed Truck...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
Ford Pickup NR (A50323)
Ford Pickup NR...
