Correct spark plug for BCS735 gasoline ALN330wb
   / Correct spark plug for BCS735 gasoline ALN330wb #1
Actonite
Acton, CA
BCS735
Apparently, Acme can't figure out the correct spark plug for this machine. Is the Champion L86 or L90 to be used? They seem to be reversed in these two Acme publications. Which is for gasoline and which is for kerosene? The NGK equivalent for the L90 is B5HS or BR5HS, while the equivalent for the L86 is B6HS or BR6HS.
   / Correct spark plug for BCS735 gasoline ALN330wb #2
I think you would want to run the cooler plug for gas and the hotter one for kerosene. I know that NGK uses lower numbers for hotter plugs. i.e. a B5HS will be hotter than a B6HS, etc
SimS
Thank you. I'll get the BR6HS.
1274 (A50490)
1274 (A50490)
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
1996 JCB 506B Telehandler (A53473)
1996 JCB 506B...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
