Correct spark plug for BCS735 gasoline ALN330wb
   / Correct spark plug for BCS735 gasoline ALN330wb #1
Actonite
Acton, CA
BCS735
Apparently, Acme can't figure out the correct spark plug for this machine. Is the Champion L86 or L90 to be used? They seem to be reversed in these two Acme publications. Which is for gasoline and which is for kerosene? The NGK equivalent for the L90 is B5HS or BR5HS, while the equivalent for the L86 is B6HS or BR6HS.
   / Correct spark plug for BCS735 gasoline ALN330wb #2
I think you would want to run the cooler plug for gas and the hotter one for kerosene. I know that NGK uses lower numbers for hotter plugs. i.e. a B5HS will be hotter than a B6HS, etc
SimS
Thank you. I'll get the BR6HS.
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
