Gale Hawkins
Super Star Member
- Joined
- Sep 20, 2009
- Messages
- 12,426
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
If they do, I hope they have done "The Mile Swim" when they were in boy scouts!
I agree about the Captain but things like that happens when one is have an panic attack.
The Captain of a Carrier that has a panic attack over a virus is unfit to command and should be relieved of duty immediately. If I am not mistaken, none of the crew has died. I doubt many of the crew are "high risk". He is not commanding a retirement home.
Did that in a lake, but it was more than a mile and scout master was pretty pissed off.
I like it!!!
:thumbsup:
Half a cup bleach to a gallon of water is fine. Clorox and most bleaches are 5-6% hypochlorite and 50,000PPM free chlorine. Half a cup in a gallon gives you a 1/32 dilution or about 1500ppm chlorine. That is plenty to kill bacteria and viruses.
Funny. I NEVER use bleach for anything, but realize I have a jug from Y2K. Good to know!
The new MedCram was talking of treatments that were done before antibiotics. The goal was to keep you from getting pneumonia because there wasn't antibiotics to treat it. They used different methods to bring temperature up to boost innate immune. One method, was to give the person malaria. They also worked with water baths, to bring temp up, and found that along with that, if they dropped the temp, so high temps followed by cold temps, increase the survival rate. They showed the level of monocytes and NK cells of people with Covid-19 were low, indicating suppressed innate immune response.
So apparently, back in the good ole days, before antibiotics, that if you got sick say from a flu, they would treat you to keep you from getting pneumonia. Compared to now, the doctor says come back when you exhibit pneumonia like conditions. They referenced other studies that showed increase of monocytes and NK cells when people used something called hypo and hyperthermic baths. So maybe a hot shower followed with cold might have beneficial effects of your innate immune system. I get that when my wife fires up the washing machine.
Bleach is chemically active and degrades quickly. I bought a used 600 gallon tank (photo) from a municipal water district, that had held a more concentrated version for chlorinating water. They put it on Ebay ($80!) when they went to something larger. The tech said it had been rinsed then the rapid decomposition of sodium hypochlorite (bleach) guaranteed it was now neutral. I rinsed it again to be sure. The rinse water didn't hurt the lawn.I believe bleach has a expiration date . . .
Thanks IT!
I use a lot of bleach, mainly for prepping wood decks around my pool. A gallon will degrade in strength in 6 months.Bleach is chemically active and degrades quickly. I bought a used 600 gallon tank (photo) from a municipal water district, that had held a more concentrated version for chlorinating water. They put it on Ebay ($80!) when they went to something larger. The tech said it had been rinsed then the rapid decomposition of sodium hypochlorite (bleach) guaranteed it was now neutral. I rinsed it again to be sure. The rinse water didn't hurt the lawn.
You need fresh bleach or else need to research how fast what you have, degrades.
Bleach can expire. After a shelf life of six months, bleach starts to degrade. Even in its original bottle, bleach becomes 20 percent less effective as each year goes by. Bleach mixed with water at a 1:9 ratio (i.e. 10 percent bleach) is potent for about a day (it's more unstable in its diluted form).
Some of have to eat. My three week supply is running out. And the government is not helping by telling us exactly where and how many are sick.
Similar sad stories everywhere. A friend with contacts in Ecuador said Guayaquil (seaport at approximately the westernmost point of South America) has bodies lined along streets because the ambulance, funeral, and cemetery businesses can't legally proceed without a Coroner's death certificate - while nobody from government or from those businesses can be found. That whole province is shut down, and has been sealed off from the rest of the country to prevent spread of the covid-19 epidemic there.This virus is making a lot of sad stories.
NYC hospital resumes use of forklift to move bodies amid coronavirus
