Corn Sheller
/ Corn Sheller #1
pajoube
Montana (Near Bozeman)
Former Owner PowerTrac 425 (September 2003)
Hand corn sheller, has anyone used one and is it easy to use? I am growing popcorn and needing something to shell the corn with and looked online and found the hand shellers but have no experience.
PJ
/ Corn Sheller #2
If you mean the type that you feed the corn in the top and you crank, then yes, I have used them and they are pretty easy. Good ones shouldn't be hard to find used, or you can buy a new one for a few hundred bucks. Now if you are talking about the little ring shaped thing that you manually run down the ear, IDK. Might work for a small amount but I'd think it could get pretty tiring.
/ Corn Sheller
Thanks for the reply, yes the hand crank type is what I was looking at. I have seen them on the internet but had no background on them until your comments.
I figure I will be shelliing about 200 ears.
PJ
/ Corn Sheller #4
Go to steam and antique tractor shows. Most of them have flea markets. I picked up two of them for $150.00. Two, because each one had some better individual parts than the other. Between the two of them, I'll have a very nice, working unit. They were made by McCormick/IHC, and work very well.
Joe
/ Corn Sheller #5
They work great for field corn. Don't know if they would remove the smaller kernel on popcorn as well. You do a lot of cranking for a bushel and will feel muscles you have't used in a while
/ Corn Sheller
Joe
I pulled a search on Bing and found many at auction sites all over the US. Problem right
now is that nothing was in my area but did post a wanted notice on Craigs List so will
see what happens. I agree, these look really good for what I need.
PJ
/ Corn Sheller
Thats why I was looking at a pulley type for use with small electric motor. The best would be to get the manifactured ones made for small operations. I posted on Craigs List so will see what happens.
PJ
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
Bush Hog 285' 3Pt Mower (A66285)
Bush Hog 285' 3Pt...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
2025 Bobcat T650 (A64126)
2025 Bobcat T650...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
