core aerator
   / core aerator #1
cowpie1
Kellogg, IA
NH TC33DA
Could anyone point me in the direction of a good manufacturer of a core aerator I could pull with my JD 320?
I am not sure best length but assume 36" probably the max. Any input from y'all would be appreciated!
Cliff
   / core aerator #2
I have used an AGRIFAB areator for more than 10 years on several commercial and large residential properties. It is about 36inches or so. Great for any garden tractor. Only repair I have had was a plastic bushing this last fall. Easy $10.00 fix after 10 years of reliable service!!!!!!!!!!
These should be avaliable at any lawn\garden center.
John
   / core aerator #6
Jason -
Can the residential model be adapted for a 3ph mount rather than tow behind?
   / core aerator #7
The residential model was designed for the home owner that did not have anything more than a lawn tractor, so it was not designed to fit a 3pt hitch. It weighs in at only 135 lbs, and has less tines per wheel. If you are using a 3pt hitch then that means you have acerage to justify a tractor, and a 30" aerator will take forever on large acreages.
Jason
   / core aerator #9
Not bad. What I was looking at on that model is the weight, construction of the frame, durability of the tines, and the amount of tines. Most people compare price against price instead of specs against specs.
Jason B Bour
Bishop Enterprises Inc Bell Buckle, TN
   / core aerator
Thanx for all the replies!! Will do my research now and make a decision! Looks like some good stuff out there. My yard is in need of aeration on a regular basis.
2014 FRAC TANK (A53843)
2014 FRAC TANK...
Ferguson Rubber Tire Asphalt Roller (A52377)
Ferguson Rubber...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
