Core Aerator
   / Core Aerator
lawn_king said:
I have a woods pl 60, its a tank! Im looking to move up to a 72" make me an offer for my pl 60?
Do you think that my BX2350 would lift that unit high enough? It is a beast.
I'll have to look at the specs closer to see how much that weighs, and what my BX is rated for. What $ ballpark do you think a used PL should be in? Being one of the most expensive models out there, I'm not sure that you could entice me. It IS a really nice unit though - no doubts there!
   / Core Aerator #12
Noob question here, but what makes one aerator better than another? I mean aside from sturdy construction what does one look for?
j
   / Core Aerator #13
ChuckinNH said:
I saw one of these at a dealer's, and it looked much better than the ones you see at Sears, etc., and was not as expensive as the more professional ones. I think it was $4-500 for the 48" version.
Husqvarna Outdoor Power Equipment - TA36
I just checked a couple of online dealers after seeing your post. If you can get one for $500 that is a deal, they list and normally sell for around $1000. I believe the Bluebird and Husky models are the same except for the paint color. They only do 3" cores to.
I still think for a 36" tow behind model this is a pretty nice unit for $650 as long as the shipping is not to high.
osCommerce or $450 for the 3pt version of same.
They also have a 30" rental/homeowner model for $300 + shipping.
osCommerce=
   / Core Aerator #14
Here is a Leinbach on my 2350... I like it because it is water-filled so I can adjust the weight as well as not worry about additional weight blocks, etc...
60" - ran about $700...
Good luck
   / Core Aerator #15
How do you replace damaged tines on the Leinbach? Are they screwed in or welded on?
   / Core Aerator #16
The leinbach design looks like an interesting one, I'd love to see more shots of it. How much does it weigh when filled with water?
Aerators need a LOT of weight. I've got 360 pounds on my Woods 48, and its still not really enough in sandy soil. They make a water tank for it (should be standard to my mind) but I'm going to build wood boxes to hold granite cobbles.
A key thing is to get a PLUG or CORE aerator, not a tine one. The tines can actually increase compaction by accounts.
I'd say what makes a good one is
Durability
Weight
Plugs
Any aerator that gets all that should be good
   / Core Aerator #17
j
Within the circle of tractor owners, the first thing to look for in an aerator is 3 point hitch compatibility. Aerating requires you to lift the unit every time you turn around, otherwise you either tear up your yard or tear up your aerator (or likely both). The tow behind is an enormous pain in the rear, while a 3 point lets the hydraulics do the work at the end of each row. On better models (once you get past Agri-Fab, Sears, etc.) the 3 point mount is usually less expensive than a tow behind.
The next thing to look for is independent or semi-independent tine wheels. If the tines are all locked onto the same axle, when you make even the slightest turn, you'll start ripping up the turf badly. A solid axle will also act as a keel, preventing the tractor from steering properly.
Also make sure the tines are standard and easily replaced. Luckily, in three years aerating my yard 3 or 4 times a year, I haven't replaced any tines yet, but the day will come when some or all will have to be changed out.
The Pro-Aire linked in an earlier response would be my first choice today. I have a Turfco 42", which has been discontinued. It has the tine wheels paired up in twos. The Pro-Aire has fully independent wheels. I think my Turfco has a better set up for ballast, but again, it has been discontinued and 60" is the smallest Turfco currently offers.
I've looked at this quite a bit, both before and after I bought mine. The Pro-Aire seems to be the best deal going right now.
   / Core Aerator #18
The cores on the Leinbach are welded on...so replacement would be more difficult. I aerate once in the spring and once in the fall - only about 1 acre, so I am not too concerned about replacement (at this point :))
Tough to estimate the weight, but here is what I know, without any front weight - and the aerator filled to capacity, the front wheels come off the ground. I run the aerator with an empty FEL and with the aerator off the ground, I still bounce the front tires if I hit a bit of a bump...
I always aerate after a good rain and have not had a problem pulling deep plugs (min 2" - mostly 3"+) - ground speed with this unit is also important, think of it as a stabbing motion in the ground - with the drum spinning faster, the cores enter deeper...and the plugs get cleared better from the cores...
I can take more pics - what in particular are you interested in?
They also offer a 4' and a 6' version...
   / Core Aerator #19
Try this: TurfVent 48" Heavy-duty 3-point Hitch Aerator - GEMPLER'S
I purchased one last year and add about 300#'s to the weight tray. Works well and seems to be good quality steel. Grease fittings are located on the axel and spoons are hardend steel. Also, doesn't weigh so much that it can only be moved by the 3PH...about 120# w/o any weight added. Not too bad a price compared to the Woods or other brand name 3PH attachements.
   / Core Aerator #20
jesseb3@att.net said:
My goal is to first roll my lawn (looks nice, but the very rough ride while mowing tells a different story!), which will of course compact it. ...
Jesse
I highly recommend against rolling the lawn. It will cause more problems (notably compaction) than it solves. Get some loam and fill in any really low spots as required.
On a recent (rare) golf outing, the cart bounced around a bit in the fairway...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
196046 (A50459)
196046 (A50459)
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2007 CATERPILLAR 257B SKID STEER (A51242)
2007 CATERPILLAR...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
JCB 5 10 56 (A50490)
