Cordless drill questions
   / Cordless drill questions #11
One last thought for you if you buy a new unit, modify the old one so you can attach it to a cigarette lighter or with battery clamps. It would make for a good backup especially if you have a portable jump starter to plug it into.
I like that idea - How would you accomplish the 12V -> 18V transformation?
Are these $229+ cordless drills really that much better than the $79 Ryobi 18V drill with 2 batteries, a charger & carrying case?
You can buy 3 drills, 6 batteries & 3 chargers for about the same price as one $229 drill :confused3:
I actually have an old 18 volt Ryobi kit, now with bad batteries. It's a good drill, if you want to drill holes or drive screws. Compared to the models I'm looking at, it's fairly heavy and pretty long. It's physically impossible to fit the Ryobi into some places on equipment that I work on in order to drill a hole. If the drill won't fit where I need it, then the price just doesn't matter.
The new drills are lighter, faster, and more comfortable. To some folks, that's worth the extra cost.
I wonder how the tools would operate on low voltage? We've run 12 volt DC motors on various voltages, from 6 to 48. It will physically operate, but for how long? In my case, running a 14 volt tool on 12 volts is only a 2 volt drop, I wouldn't be surprised if the factory batteries drop that much under a load.
In particular working on forklifts, I can simply use alligator clips to connect to the forklift battery and get whatever voltage I need.
   / Cordless drill questions #14
I'm a contractor and I used my tools every day. I'm abusive on them, and I work them pretty hard all year long, year after year.
I started out with DeWalt and have found them to be affordable, easy to find, and totally dissapointing. I've come to think of them as a middle of the line, home hobby brand. Fine for a weekend project, but not what I'd want to rely on to make a living.
I've only found two brands that consistantly impress me. Bosch and Makita.
Eddie
   / Cordless drill questions #15
The only difference that I know of between the 2 Makitas you are looking at is the color and the battery capacity. The white one is 1.5 Amp-Hours and the blue is 3.0 AH. They are the same otherwise and you can interchange the batteries (for the most part - some of the heavy draw blue tools won't accept the small battery, I think). So double the run time for the blues.
   / Cordless drill questions #16
I use drills everyday at work and I have had issues with Dewalts, porter cables, and makitas. Dewalt probably the most. I haven't owned a Milwaukee, but they are supposed to be real good. I would have never believed it, but the new craftsman 19.2v drills are very good. I have run them exclusively for the last 5-6 years and have only had one bad battery ( the older thick one). The new lithium ion batts are light and I've not had one hiccup. Best part is the craftsman are comparatively inexpensive and you can upgrade to the extended in store replacent warranty for just a few bux more.
Ridgid might be worth a look too. I don't have their drill, but the cordless nailer I have had a bad battery, HD replaced it free of charge even though I'd owned it for a year and had no receipt.
   / Cordless drill questions #17
I have a 12 YO Dewalt that i still use. My Milwaykee 28V is powerfull, but very heavy. Man do they last though.
   / Cordless drill questions #18
Enter 338116 into homedepot.com's search. That's the SKU for it.
i got a kit at harbor freight.. cordless drill and led lamp, bat and charger.. 12.99 with regular ( non 20% ) coupon.
thing works great.. so good I bought a 2nd set for the house.. heck.. the spare bats cost 75% as much as the kit.. I maybuy a 3rd kit just for the bat...
   / Cordless drill questions #19
Hmm, sounds like the set my FIL bought a bit over a year ago. It is now dead and beyond warranty. Appears it's not charging properly, something to add to my repair list.
   / Cordless drill questions #20
I was just talking about that with a guy at work today. Doesn't seem like it would be too hard to turn an old battery pack into a dummy leading to some long cables.
Exactly. You can leave the batteries in for weight balance if you want just disconnect the cells and run similar gauge wire out a hole in the bottom. I've connected my 14.4v cheapo Ryobi to a 12V battery and it runs as fast as the battery I have which I'm sure is tired because it doesn't last long. One thing I would recommend is adding a fuse inline so you don't burn out anything. Also, be careful plugging into a car cigarette adapter because nowadays they have smallish fuses in them so you could blow the fuse if you bog the drill down. The lower voltage is not a big deal it will just go slower at max speed but should have gobs of torque. My 1st thought was to do this for my popup camper so I could quickly put down the jacks without bringing my good drill but it would be useful in many places seeing I have a portable jump starter.
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
John Deere 5055E (A53317)
John Deere 5055E...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
