Copying Table?
/ Copying Table? #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
Is there a device like a CNC plasma cutting table that follows a pattern, armstrong powered?
edit: or is it easier to just cut around a pattern?
/ Copying Table? #2
ESAB used to have 2 versions. One used an electric eye to follow a drawing. The other used a knurled roller that would roll along a cut out metal patern on the top of the machine and cut the same part below on your table. No CNC on either one. I see these for sale from time to time. Seems like one was called an Auto-Graph or something like that.
/ Copying Table?
I was thinking about one of those.. but I guess if you can just run the torch around a pattern, it's more like what I would be doing. A torch held by something other than my hand would probably be steadier tho.
/ Copying Table? #5
We have one at my job, its called a surfograph. It is great for production work but very complicated to program, and if making one off projects its not really worth the time for the set up process. Our unit is very old tho and im sure the newer ones would be a little easier on the programing end. But very good unit like I said for production work if you offset your patterns you can really get your moneys worth out of a sheet of steel.
/ Copying Table? #6
My Hypertherm plasma is made for drag cutting.....and made to guide along next to a template...be it cardboard, plywood...or metal.
This one is a Powermax30....cuts up to 1/2".
Jim
/ Copying Table?
Jim
That's what I was looking for, thanks.
/ Copying Table? #8
This is what I made . I just make a template out of plywood and the syltus follows the shape and the parts come out very clean. It is great for smaller parts and multiple pieces.
/ Copying Table? #9
You made this? Very cool. May have to copy it. :thumbsup:
/ Copying Table?
That's the ticket right there! :thumbsup:
/ Copying Table? #11
Did you make the X Y table/holder thing? Do you have plans?
/ Copying Table? #12
I made the whole thing from scratch. The size was based on what I had for materials so there are no plans. It was my first welding project for the spool gun.
The carriers were made from the bearings I got from in-line skate wheels. Surplus Center has them for 2.99 a pair which is .50 cents for each bearing.
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2013 HAULMARK ENCLOSED UTILITY TRAILER (A67714)
2013 HAULMARK...
1998 Freightliner MT45 Chassis Truck (A66736)
1998 Freightliner...
2014 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2014 Chevrolet...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
