Copying Bseries loader feasible?
   / Copying Bseries loader feasible? #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Don't know if anyone out there has tried this but would it be feasible to "copy" the kubota Bseries loader??
At $4000.00plus from the dealer I do not plan to spend this $$ as I could use it other places ...but would really like a FEL
I have a coworker that has the same machine with FEL and was thinking of copying this loader to the millimeter.
I do not want an aftermarket loader and do not plan on buying P.F. engineering plans.
Let me know
   / Copying Bseries loader feasible? #2
Let me know
Go for it! But wouldn't your home-built FEL be considered "aftermarket" also?
   / Copying Bseries loader feasible? #3
I sort of copied the B-series idea of a single dump cylinder if that is the one you are talking about. Cost about 1,500 to build.
   / Copying Bseries loader feasible? #4
I am just wondering how much you can save?
Valve $350
Cylinders $500
Hoses $300
Nuts and bolts sleeves bushings zerks $150
Steel $500
Paint ect $100
From my calculations you would have about 2 grand in the supplies. Yes, this is a savings but it will take a lot of time and work.
It can be done and will be a fun project but think it out first and get a good shopping list.
Chris
   / Copying Bseries loader feasible? #5
Valve $350
Cylinders $500
Hoses $300
Steel $500
Paint ect $100
Chris
I think your calculations are generally correct, I certainly won't argue that you could spend that on those items. I was able to build mine for much less though ( for a loader larger than a B series type). I purchased the metal from the local scrap yard for $0.25/lb. The cylinders and control valve were (mostly) various new old stock items I purchased off ebay. I will admit that I watched many auctions and waited patiently to find the best deals I could but ended up with about $275 in those item including shipping. The control valve was a New Holland unit with bracket, fittings and quick connect set up that retailed for about $700, the tilt cylinders were new ( I had to cut down and reweld them) but were only about $50/pair. The lift cylinders were good used but only about $75/pair. I bought all of my hoses, fittings, zerks, pins, bushings and paint at Rural King farm supply store. I really don't have an "exact to the penny" figure on everything but I feel comfortable in saying that I have about $600 in everything I have spent on it including welding and cutting consumables. I will emphasise that it took close to a year to collect everything I needed to build it so that was a lot of patient auction watching and several trips to the salvage yard but I like to do that anyway so it was not a real burden for me and was really a part of the "challenge".
I think that anyone with decent welding skills and basic cutting tools can tackle this job. It may seem a little intimidating but it really isn't that difficult and as they say, " Rome wasn't built in a day"....start with a plan and begin making it piece-by-piece. Before too long you've got something that is coming together and you realize this is something you really can do yourself. A couple of months of weekends in the garage/shop and you've got it whipped.
Thanks for the replies;
I know that the US version of the same Canadian loader costs $1000.00 less.
So I would be down to $3000 plus exchange.
Will probably attempt since I really enjoy welding and fabricating.
   / Copying Bseries loader feasible? #7
Do you ever plan on upgrading/trading/selling your current machine? I only ask because from a resale point of view a loader (especially a factory loader) is a critical piece of the puzzle....
   / Copying Bseries loader feasible? #8
Go for it! Absolutely!
Plans would be nice to help out with some of the geometry, but not necessary.
I'm working on a backhoe, and I've stopped a number of times after hours at rental yards to take measurements and get ideas.
Spudland Dave,
Yes a factory loader is nice but what I am talking about is basically an identical copy or an L364 loader. Stickers and all.
I would tell people that I did copy and build it but nobody would know the diffence unless they asked
   / Copying Bseries loader feasible? #10
I would look at selling the tractor and finding one with a loader first, if the costs were comparable. I traded my b6200 for a b7500 and the cost difference was well worth it to me, lower hours on the b7500,larger loader, power steering, more horsepower , 12 years newer and larger 3pth cap.
2024 Deere 317G (A50123)
2024 Deere 317G...
2239 (A51244)
2239 (A51244)
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
New Holland C238 (A50123)
New Holland C238...
