Copper Tig welding.
/ Copper Tig welding. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
This subject comes up every once in awhile, and I've never seen it done. So I thought I'd give it a try. Took four hundred forevers to get the filler rod from weldingsupply.com!:mad: Back ordered, and all:rolleyes:.
Started on some 1/8" x 1" flatbar. Did some corner joints, lap joint, and a fillet weld. Used 3/32-inch Ceriated tungsten, at 150-amps, with 100 % pure argon. Took a little bit to get enough heat built up to form a puddle. But didn't take to long until I was backing out of the pedal. In some ways it reminds me of welding aluminum, except the puddle looks dirty. I used a brand new steel wire wheel on a 4-inch hand grinder to clean the base metal before welding. After welding I tried a new Scotch-Brite pad, but wasn't very successful, so I used a new stainless steel hand brush. I learned if I let everything cool to the touch, the black cleaned off easier. Soon as I lifted my hood after welding, every piece was glowing red hot!
I tried a couple welds on 1/4-inch material, it took all 300-amps to weld the 1/4-inch!
Kind of fun to do, learned something new today!:cool:
/ Copper Tig welding. #2
Nice looking welds...now go get a job maintaining the Statue of Liberty. :)
I have enough issues with aluminum although have produced some nice looking welds on it. I'll bet that copper plate was costly!
/ Copper Tig welding. #3
Just out of curiosity, do you think that you could use the solid wire out of Romex for a small job or one time use if the need ever arose?
now go get a job maintaining the Statue of Liberty. :) I'll bet that copper plate was costly!
JOB?! That's the last thing I want.:laughing: That flatbar was $8.00 a foot.
I've read on some welding forums where people have had good success with like 12-GA Romex wire.
/ Copper Tig welding. #5
Shield you desribed it perfect bud, very similar to aluminum. Heres my filler wire, works perfect and blends and polishes great!
/ Copper Tig welding. #6
If it took 150 amps for 1/8in and 300amps for 1/4, does than mean I can do 1/16 with 75amps. Yes this is a real question.
Sounds reasonable to me. But I would think copper is a bigger heat sink than aluminum, so the bigger the item being welded the more heat you'll need.
/ Copper Tig welding. #8
That thin 28 gauge I just showed was welded if I remember correct at 90amps. Yowza, it was paper!
/ Copper Tig welding. #9
Did you have it clamped in that huge heat sink vise when you welded it? or maybe I am not understanding something correctly.
No I didn't,:confused: but I only have two hands. One to hold the Tig torch, the other to hold the filler rod. So the vice comes in real handy to hold things for me.:confused:
I played with some 1/16-inch wall pipe this morning. 120-amps seem to work fine to get a puddle going, but again it didn't take long before I was backing out of the pedal.
/ Copper Tig welding. #12
I wonder what kind of amps you'd need if you preheated. Do they have a flux cleaner for Copper?
/ Copper Tig welding. #15
Thats exactly what I was thinking about welding. Got to put together a moonshine still you know.
/ Copper Tig welding. #16
Looks good. I don't think I would have bothered ordering proper welding rods though. With how cheap I am, I would have to try it with scrap electrical wire before spending anything.
/ Copper Tig welding. #17
From what I have read, copper wire has a tendency to make a porous weld. Havent tried it so dont know if thats true or not. If true, I think the copper wire wouldnt be a good choice if you where going to do any structual or pressurized pipe welding. For what ever I would be doing, it would be ortamental so I suspect the copper wire would do just fine. Now just where did I put those moonshine still plans.
/ Copper Tig welding. #18
I've been following this. Though I have never tried it (on my welding "bucket list") regular copper wire is pretty much pure copper, so it should not cause any problems in a copper weld.... Protected from oxidation by the insulation too, at least to some degree...
/ Copper Tig welding. #19
It works perfect bud, trust me ;)
32ft T/A Flatbed Tag Trailer (A66736)
32ft T/A Flatbed...
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2021 Vermeer STR48 Hydraulic Trencher Attachment (A64912)
2021 Vermeer STR48...
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
