Loader Copper hydraulic lines?
/ Copper hydraulic lines? #1
jiminsulator
Buffalo, New York
cabellas wlm 35h
Any one have problems with hard hydraulic lines, had one work harden and break.. only 50 hours on machine.. line was copper!! It's a return line it still...
/ Copper hydraulic lines? #2
If theres a filter in the return there may be some pressure. Seems like it would be safety bypassed at way less than 200 and copper would take that. Is there a lot of vibration or perhaps a return obstruction? Did it spurt violently?
/ Copper hydraulic lines? #3
Is this seeing vibration? Suspect yes since that would lead to work hardening and breaking. I have seen this happen on oil cooler lines on other brands of tractors.
/ Copper hydraulic lines? #4
Replace the vibrating section with hydraulic hose. The copper is surprising as steel seems to be standard for dynamic things like tractors. A short piece of hydraulic hose where it broke may help also. Copper get brittle way faster than steel.
Ron
/ Copper hydraulic lines? #5
Copper as a return to tank line is fine. Mounting an fixing against movement may be an issue, I'm sure you can meet that challenge!
Make up a new line, secure it well.
It's under warranty and needs its 50 hour service so I'll have them replace it.. but if I have more issues I'm gonna replace with steel if they don't..
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
1762 (A58375)
1762 (A58375)
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2019 East...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
