Cooling fan intermittent
/ Cooling fan intermittent #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So, my cooling fan is about to die I think. Ordered a new one from Amazon. Basically it stopped spinning. Spent a long time making sure it was the fan (checked it last, of course). It is a SPAL 14" low profile.
But of course. I order the new one up (the old one is not spinning) and put the old one back on. Decide to spray it with WD40 and give it a love tap or two with a hammer and it is working like a charm.
/ Cooling fan intermittent #2
Your problem could have been wiring or temp switch.
I replaced my hyd cooling fan with an auto radiator fan. About $20 to $30.
/ Cooling fan intermittent #4
I Have had the fuse holders become intermittent. Check this.
/ Cooling fan intermittent #5
That's a good price, but the Spal fans on the larger PT's already are Auto radiator fans. I have a feeling that they were not particularly designed to be mounted flat, and may have less life because of it. I have gone through a fan on my 1460, and it only has about 200 hours on it.
I changed the wiring so that the temp switch goes to a starter relay, which then turns on the fan. The temp switches are improperly used on these tractors.
Meaning you wired a relay into the fan circuit as the temp switch us underrated for the amperage of the fan?
/ Cooling fan intermittent #7
Yep..... It should last forever now....
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Wacker Neuson...
(2) BUCKETS OF GALVANIZED BOLTS (A64281)
(2) BUCKETS OF...
2006 Ford F-150 4.6L V8 Gasoline Engine (A61573)
2006 Ford F-150...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
2017 Chevrolet Express 3500 14FT Box Truck (A61573)
2017 Chevrolet...
John Deere 672GP (A64126)
John Deere 672GP...
