Cooling fan intermittent
/ Cooling fan intermittent #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So, my cooling fan is about to die I think. Ordered a new one from Amazon. Basically it stopped spinning. Spent a long time making sure it was the fan (checked it last, of course). It is a SPAL 14" low profile.
But of course. I order the new one up (the old one is not spinning) and put the old one back on. Decide to spray it with WD40 and give it a love tap or two with a hammer and it is working like a charm.
/ Cooling fan intermittent #2
Your problem could have been wiring or temp switch.
I replaced my hyd cooling fan with an auto radiator fan. About $20 to $30.
/ Cooling fan intermittent #4
I Have had the fuse holders become intermittent. Check this.
/ Cooling fan intermittent #5
That's a good price, but the Spal fans on the larger PT's already are Auto radiator fans. I have a feeling that they were not particularly designed to be mounted flat, and may have less life because of it. I have gone through a fan on my 1460, and it only has about 200 hours on it.
I changed the wiring so that the temp switch goes to a starter relay, which then turns on the fan. The temp switches are improperly used on these tractors.
Meaning you wired a relay into the fan circuit as the temp switch us underrated for the amperage of the fan?
/ Cooling fan intermittent #7
Yep..... It should last forever now....
2014 FEATHERLITE GOOSENECK LIVESTOCK TRAILER (A63291)
2014 FEATHERLITE...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
1983 INTERNATIONAL 1954 FLATBED TRUCK (A63291)
1983 INTERNATIONAL...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2017 Volkswagon CC Sport Sedan (A61574)
2017 Volkswagon CC...
