coolant recovery tank gurgling
   / coolant recovery tank gurgling #1
blue262
Louisiana
2006 Kioti CK25
I have a 2006 CK25 with 501 hours. Today I was using it to push trees around into my burn pile. While I was off the tractor and it was sitting at idle I noticed antifreeze dripping onto the ground. I popped the hood and saw the coolant recovery tank was gurgling and the antifreeze was coming out. I then saw the temperature indicator was showing hot. I stopped the engine to think about what might be causing this. I waited an hour and popped the radiator cap and could not see a level in the radiator. I may have lost this much during the gurgling. I restarted it and the gurgling started again. I stopped the engine and parked it. Could this be from a blown head gasket? Any other ideas?...Please have some. I don't want a blown head gasket!
   / coolant recovery tank gurgling #2
Was it bubbling like air was being forced out or was it boiling
compression test will quickly tell you if you've got bad head gasket wich replacing would not be a big deal
I you boiled over you need to be very carefull could be very easy to have heat seizure and then you'd be in a bad spot
check compression first off
also check your water pump to be sure it is circulating the water also check radiator for obstruction
good luck
Joel
I did confirm the belt was turning the fan and the water pump. I think it was bubbling out as in air bubbles. I really didn't detect a lot of heat. I was kind of surprised to see the temperature gauge indicated hot because the engine didn't feel hot. I know how to do a compression test on gas engines, through the spark plug holes. How is this done on diesel engines?
   / coolant recovery tank gurgling #4
Where are you located? Could it be frozen?
   / coolant recovery tank gurgling #5
Check the oil dipstick for signs of coolant in the oil. Also check your coolant for any signs of oil.
I'm in south Louisiana. It's been cool but not cold enough to freeze anything.
   / coolant recovery tank gurgling #7
Check through the glow plug hole or injector hole
Joel
   / coolant recovery tank gurgling #9
There are several ways to check for a compression leak into the cooling system..
On a cold engine, I would start by filling the cooling system completely full of coolant or water, replace the radiator cap, remove the recovery bottle hose from the radiator neck and attach a clear piece of flexible tubing that will reach to the ground. The tubing can be purchased from Lowes or Home Depot for about 30 cents a foot.. so its cheap. Place the other end into a partially filled bucket of water and start the engine.. IF its compression leaking, it will QUICKLY overcome the pressure rating of the raditor cap and start pushing some air thru the tubing and eventually start blowing bubbles into the bucket of water..
You WILL see some bubbles from the small amounts of trapped air in the system and in the clear hose, but what you are looking for is consistently seeing air bubbles as the engine runs.... Thats compression entering the cooling system.
I WOULD suggest that you run the engine until it gets operating temp,. then shut it down, remove the glow plugs(if equipped) and spin the engine over... BUT, not knowing your experience level makes me want to tell you to shy away from that.... Personal bodily injury could result from not being careful..
Also, doing that may NOT show true results due to leaking head gaskets not ALWAYS leaking back into the cylinders... sometimes the leak is sealed until combustion pressure hit the affected area...
Try the hose in the bucket trick.. its a time tested troubleshooting method..
   / coolant recovery tank gurgling #10
How about the air flow through the radiator + screen are they clean?
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2121 (A51244)
2121 (A51244)
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
