Coolant Questions
/ Coolant Questions #1
MMH
Murrysville, PA
JD 4500
Does a B9200 have any special coolant specifications? Will any 50/50 Ethylene Glycol mix work? Do I need to add any SCA/FW-16?
/ Coolant Questions #2
Regular green coolant will be perfectly fine.I use a 50/50 mix with distilled water.The pre-mixed coolant with de-ionized water would be even better and easier.Good Luck!
/ Coolant Questions #3
I used diesel coolant when I changed mine. Not sure what the difference is, but it said diesel on the container so it sounded like a good idea.
/ Coolant Questions #5
Any special coolant for diesel engines is for newer engines.The OP's B9200 is a parent bore(no cylinder liners)engine which would have come with ethylene gylcol coolant as the factory fill.Drain and refill every two years,using distilled water or de-ionized water to elimate any unwanted chemicals(lime here)is all that is needed.
A comment from fieldserviceengineer from the Oils,Fuels & Lubricants section would clear this up,but I am confident in my recommendations.Good Luck!
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
