Coolant leak question TC33D
   / Coolant leak question TC33D #21
bumping this thread hoping for an update as I also have this problem with my 2008 T1520. Thank-you,gentlemen,for all your knowledgeable input on this topic.
The setup I mentioned in the post above yours is working great, no problems and no more leaks.
It was a little awkward getting the barb fitting pointing in the correct direction and getting it tightened properly. At first I didn't have much faith in it but I've worked the tractor for 5-10 hours now, both the engine block and garage floor are dry.
There probably is a better setup out there but this is working fine on my TC45D
   / Coolant leak question TC33D #22
thanks for the feedback blee03. I purchased a bspt brass plug from mcmaster-carr and I'm going to wait to install it till I take my front snowblower off for the year (I live in northern mi.)
   / Coolant leak question TC33D #23
Blee03, I have a question. I see the parts you ordered but how did you account for the drain portion. From the 2 parts you've shown it looks like the antifreeze would just pour out. Did you use a petcock or something? Thanks
   / Coolant leak question TC33D #24
My tractor didn’t have a petcock attached to the block, just a standard fitting.
The hose that comes out of the new fitting I installed goes towards the radiator along the frame rail and there is a plastic drain valve spliced in from the factory.
I used this drain to remove most of the radiator fluid before I installed the new brass fittings
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
John Deere Quick Hitch (A53317)
John Deere Quick...
2017 Vermeer BC1800XL Towable Brush Chipper (A55851)
2017 Vermeer...
2016 Fiat 500X (A56859)
2016 Fiat 500X...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
UNUSED KJ CHICKEN COOP (A57193)
UNUSED KJ CHICKEN...
