Coolant leak question TC33D
   / Coolant leak question TC33D #21
bumping this thread hoping for an update as I also have this problem with my 2008 T1520. Thank-you,gentlemen,for all your knowledgeable input on this topic.
The setup I mentioned in the post above yours is working great, no problems and no more leaks.
It was a little awkward getting the barb fitting pointing in the correct direction and getting it tightened properly. At first I didn't have much faith in it but I've worked the tractor for 5-10 hours now, both the engine block and garage floor are dry.
There probably is a better setup out there but this is working fine on my TC45D
   / Coolant leak question TC33D #22
thanks for the feedback blee03. I purchased a bspt brass plug from mcmaster-carr and I'm going to wait to install it till I take my front snowblower off for the year (I live in northern mi.)
   / Coolant leak question TC33D #23
Blee03, I have a question. I see the parts you ordered but how did you account for the drain portion. From the 2 parts you've shown it looks like the antifreeze would just pour out. Did you use a petcock or something? Thanks
   / Coolant leak question TC33D #24
My tractor didn’t have a petcock attached to the block, just a standard fitting.
The hose that comes out of the new fitting I installed goes towards the radiator along the frame rail and there is a plastic drain valve spliced in from the factory.
I used this drain to remove most of the radiator fluid before I installed the new brass fittings
OKI C6900 Printers (A53425)
OKI C6900 Printers...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2006 INTERNATIONAL 9400I DAYCAB (A55745)
2006 INTERNATIONAL...
2019 FORD F-350 FLATBED DUALLY (A55745)
2019 FORD F-350...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
Cybex Elliptical (A53425)
Cybex Elliptical...
