WilliamTO-35
I've been using my 1955 Ferguson TO-35 with the Z134 gas engine for 35 years now , with no unusual engine problems. At the end of last winter, however, I was pushing some snow and steam started pouring out of the radiator cap. I parked the tractor and shut it down within about 30 seconds. When the engine cooled, the radiator was about a gallon low on coolant. I assumed there were radiator leaks, although I never found any significant leaks. When I changed the engine oil this summer, I found about a half pint of coolant in the engine oil. I've only run the tractor at idle for about 20 minutes since I found the coolant in the oil, but it's too late in the season to do any repairs. I put some stop leak in the radiator, and I'm leaving the radiator cap loose , hoping that I can make it through the winter . Next spring, I'm expecting to find a blown head gasket , but often on an older engine there's more damage than you expect. I removed the spark plugs and cleaned them, with no indication of any one cylinder getting coolant into the combustion chamber. There's no white smoke coming out the exhaust at idle. This engine has wet cylinder liners, so coolant could be getting in through the lower sleeve seals. What's the most likely damage I'll find on this engine? Could I be lucky, and just find a blown head gasket, or is it likely the overheating caused more complicated problems ? If I need to plow snow with the tractor this winter, I plan to keep an eye on the engine oil, and if I start finding more coolant, I'll just have to stop using the tractor entirely until I tear it down.
