Coolant in Oil
/ Coolant in Oil #1
WilliamTO-35
Northeast USA
1955 Ferguson TO-35
I've been using my 1955 Ferguson TO-35 with the Z134 gas engine for 35 years now , with no unusual engine problems. At the end of last winter, however, I was pushing some snow and steam started pouring out of the radiator cap. I parked the tractor and shut it down within about 30 seconds. When the engine cooled, the radiator was about a gallon low on coolant. I assumed there were radiator leaks, although I never found any significant leaks. When I changed the engine oil this summer, I found about a half pint of coolant in the engine oil. I've only run the tractor at idle for about 20 minutes since I found the coolant in the oil, but it's too late in the season to do any repairs. I put some stop leak in the radiator, and I'm leaving the radiator cap loose , hoping that I can make it through the winter . Next spring, I'm expecting to find a blown head gasket , but often on an older engine there's more damage than you expect. I removed the spark plugs and cleaned them, with no indication of any one cylinder getting coolant into the combustion chamber. There's no white smoke coming out the exhaust at idle. This engine has wet cylinder liners, so coolant could be getting in through the lower sleeve seals. What's the most likely damage I'll find on this engine? Could I be lucky, and just find a blown head gasket, or is it likely the overheating caused more complicated problems ? If I need to plow snow with the tractor this winter, I plan to keep an eye on the engine oil, and if I start finding more coolant, I'll just have to stop using the tractor entirely until I tear it down.
/ Coolant in Oil #2
I've been using my 1955 Ferguson TO-35 with the Z134 gas engine for 35 years now , with no unusual engine problems. At the end of last winter, however, I was pushing some snow and steam started pouring out of the radiator cap. I parked the tractor and shut it down within about 30 seconds. When the engine cooled, the radiator was about a gallon low on coolant. I assumed there were radiator leaks, although I never found any significant leaks. When I changed the engine oil this summer, I found about a half pint of coolant in the engine oil. I've only run the tractor at idle for about 20 minutes since I found the oil in the coolant, but it's too late in the season to do any repairs. I put some stop leak in the radiator, and I'm leaving the radiator cap loose , hoping that I can make it through the winter . Next spring, I'm expecting to find a blown head gasket , but often on an older engine there's more damage than you expect. I removed the spark plugs and cleaned them, with no indication of any one cylinder getting coolant into the combustion chamber. There's no white smoke coming out the exhaust at idle. This engine has wet cylinder liners, so coolant could be getting in through the lower sleeve seals. What's the most likely damage I'll find on this engine? Could I be lucky, and just find a blown head gasket, or is it likely the overheating caused more complicated problems ? If I need to plow snow with the tractor this winter, I plan to keep an eye on the engine oil, and if I start finding more coolant, I'll just have to stop using the tractor entirely until I tear it down.
I don't want to be an alarmist, but the Z series Continentals are prone to cracking. It's particularly true for the Z-129. That said, I've not heard of a endemic cracking problem on the Z-134.
Overheating can be caused by a loose fan belt, clogged air side on the radiator, clogged coolant passages in the radiator, stuck closed thermostat, collapsed lower rad hose, corroded pump impeller, overly lean mixture etc. . This could have caused the head to warp and/or the head gasket to blow. With the engine running at operating temperture, if the head gasket is blown, you may see bubbles in the coolant. Have you noticed any additional coolant in the crankcase? If not, you may have lucked out by shutting down so quickly. As you imply, the other possibility is that the o-ring sleeve seals at the bottom of the sleeves are cracked and leaking.
You're taking the right steps to get through the winter. Do you have a temperature gauge? If so carefully monitor that during operation.
However you need to find out the cause of the over heating. If you have a rotary cutter and mow with it, it's quite posible that the air side of the rad is blocked. Check the thermostat for opening, make sure the fan belt is correctly tensioned. With the engine at operating temperature, observe the lower rad hose at idle and at max rpm to make sure it doesn't collapse. Make sure that your carb's power jet screw is not open any less than one full turn.
When the tractor is not critially needed, I'd screw the rad cp back on and operate the tractor normally to see if there are any problems. As I said, you may have lucked out.
/ Coolant in Oil #3
I'll have to respectfully disagree.
Coolant in the oil is cause for alarm. It can and will 'wash out' the main bearings and that engine will lock up. It's not a matter of "if it will" its a matter of "when it will".
Personally, I would not run that engine untli it is repaired.
Liners could have holes in them also (cavitation), allowing coolant into the oil.
/ Coolant in Oil #4
G'day not sure if it is the same engine but seem to remember an alloy casting plug in the top of the head that had a habit of corroding out, IIRC the part is threaded into the head and is nla, if it is only a pinhole i have seen then drilled and tapped to take a 1/4 bolt with a fibre washer. You will have to remove rocker cover to see it. I would try a good leak sealant first if you do not have the time to fix now BUT i would be keeping a very close eye on both water and oil every time you use it
Jon
/ Coolant in Oil #5
I agree totally. Only a matter of time now.
/ Coolant in Oil #6
I've.never heard of a gas engine having cavitation damage to liners.
/ Coolant in Oil #7
I've never heard of anyone recommending running an engine with coolant in the oil.
/ Coolant in Oil
Thanks all for your advice. If I keep finding coolant in the oil, then I'll definitely park the tractor . Whatever damage occurred to cause this problem no doubt occured during the brief overheating episode last winter. It's possible that coolant will only get into the crankcase during an overheating episode. It's also possible that the radiator stop leak might plug up the source of the leak, or that running with the radiator cap loose will eliminate the problem. Sure, I'd have to be lucky for the coolant leak to disappear for the above reasons, but I don't run the tractor very often, and if I don't have to tear down the engine, I'd rather not. I also have a front loader which makes access to the engine more difficult. At this point, I plan to run the engine for only half hour periods before I check the oil again. If there's more coolant in the oil, then I'll have to park the tractor until spring. This tractor is my main snow mover during the winter. However, I bought a walk behind snowblower last season, and I may have to rely on that for snow moving this winter.
/ Coolant in Oil #9
The best way to check for coolant in the oil is to let the tractor set over-nite and crack the oil pan plug and see what comes out first. Coolant or oil.
/ Coolant in Oil #10
The only stop leak product I ever use is the silver flakes in the plastic tube. You can get corrosion that will eat threw a casting or more likely an internal frost plug, normally in the head.
Removal of the valve cover and the oil pan and pressurise it when cold will find the leak. It will not get cheaper or magically heal itself.
Just a thought!
/ Coolant in Oil #11
More likely frost plug damage.
Antifreese will eat at the white mettal in your bearings.l
Putting the stop leek into the water is not the answer as it will cause other problems in the winter. Black Ground Peper is one of the best, cheepest to temporary stop the leek
Frost Plugs are about $1.00 each so are cheep.
/ Coolant in Oil
I'm a bit nervous of what I'm going to find when I eventually have to tear this engine down, which I probably will . While the following happened to my Chevy 350 pickup engine, I may find the same problems with my Ferguson.
As nearly as I can determine, the head gasket on the truck engine blew on #7 cylinder, between the cylinder and a water cooling passage. That created a gas bubble in the cooling system, which caused the water pump to cavitate, and the temperature on the dash gauge to suddenly rise . ( I noticed that.) The overheating caused a head bolt to break. The head bolt that broke was the one in the path of all the oil returning to the crankcase at the firewall end of the head. That allowed oil in great quantities to get sucked into #7 cylinder, causing clouds of smoke out the tailpipe. When I removed the cylinder head, I found several hairline cracks in the head, and both the head and the block deck surface had been erroded away by the combustion gases escaping through the blown gasket channel. The head was replaceable, but the erroded channel in the block deck was a different matter. I put a lot of time and money into an attempted repair, but in the final analysis there were too many problems with the well worn engine to proceed any farther. The truck is now a lawn ornament. I'd sure hate for my Ferguson to become a lawn ornament too.
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
208320 (A58375)
208320 (A58375)
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
