Coolant Drain Plug Question
   / Coolant Drain Plug Question #1
Professor Marvel
Platinum Member
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
The drain cock for coolant on the block of my New Holland tractor corroded and broke off. I cleaned the mess up and chased the threads with a 3/4 in pipe tap. I replaced it with a 3/4 to 1/2 brass bushing with a 1/2 brass plug in it to drain it with. Is there any problem using brass in the block with electrolosis type corrosion due to dissimilar metals? If not, I like my new set up better than the original.
Thanks for input
   / Coolant Drain Plug Question #2
Maybe put some teflon tape on the threads?
Yes Sir
Put Teflon tape on all joints so that should help but I just wanted to make sure that there is no dissimilar metals problem
   / Coolant Drain Plug Question #4
There's no problem using brass fittings on the block, just put sealant on the threads.
   / Coolant Drain Plug Question #5
they make a thread treatment to prevent any problems with dissimilar metal.. however I'd seldom had problems with brass plugs into cast iron ..
Thanks for the input folks. I put plenty of teflon tape on it so now I feel confident with the repair.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
UNUSED AGT 3 PT 82" ROTARY TILLER (A51248)
UNUSED AGT 3 PT...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
