Coolant Drain Plug Question
   / Coolant Drain Plug Question #1
Professor Marvel
Platinum Member
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
The drain cock for coolant on the block of my New Holland tractor corroded and broke off. I cleaned the mess up and chased the threads with a 3/4 in pipe tap. I replaced it with a 3/4 to 1/2 brass bushing with a 1/2 brass plug in it to drain it with. Is there any problem using brass in the block with electrolosis type corrosion due to dissimilar metals? If not, I like my new set up better than the original.
Thanks for input
   / Coolant Drain Plug Question #2
Maybe put some teflon tape on the threads?
Yes Sir
Put Teflon tape on all joints so that should help but I just wanted to make sure that there is no dissimilar metals problem
   / Coolant Drain Plug Question #4
There's no problem using brass fittings on the block, just put sealant on the threads.
   / Coolant Drain Plug Question #5
they make a thread treatment to prevent any problems with dissimilar metal.. however I'd seldom had problems with brass plugs into cast iron ..
Thanks for the input folks. I put plenty of teflon tape on it so now I feel confident with the repair.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT IDENTIFIER 42 (A53084)
A1 MIST SPRAYERS...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
