Coolant change, what do you use?
   / Coolant change, what do you use? #11
Thanks ray66, I was thinking there was some additives, but unsure what additives.
That is something I didn't know. Wonder what actually makes it "cavitate"? Does it get so hot it disintegrates ??
A small excerpt I found:
One of the most common and costly results of improper cooling system maintenance is the perforation of wet-sleeve cylinder liners. The perforation is caused by repetitive pitting of the liner resulting from liner vibration. As the fuel inside ignites, the liner vibrates within the block. The outside wall of the liner actually moves away from the coolant causing a near vacuum for an instant. This low-pressure causes the surrounding coolant to boil, forming tiny bubbles. The liner then returns to its position with extremely high velocity, pressing against the bubbles with a violent force. The bubbles implode (collapse) against the liner wall surface at pressures up to 60,000 PSI. The collapse of these bubbles blasts small holes in the steel liner. This pitting process will repeat, digging tiny tunnels through the liner. This will eventually perforate the wall allowing coolant to enter the combustion side of the cylinder
Full article:
Protect Your Engine with the Right Antifreeze
   / Coolant change, what do you use? #12
thus my post about a cavitation and electrolysis addative..
soundguy
Thanks guys.:thumbsup: I was looking though the owners manual and it says just to use ethylene glycol and water, 50/50. Does not mention anything about additives???:confused:
   / Coolant change, what do you use? #14
Pay attention, I already went over that. :confused3:
Diesels normally require antifreeze that contains extra additives for diesel engines. According to the book of MF, you can use regular antifreeze in these. However, MF wants you to change the coolant annually, suggesting they have concerns about the antifreeze additives lasting in these engines.
I understand that, just curious as too WHY wouldn't they want to put the additive IN to eliminate all questions:confused:? Or do they not add it because it corrodes or does not lubricate well? I am totally new to diesel proper maintenance, just want to do everything possible I can to have this thing around for a LOOONG time.:thumbsup:
   / Coolant change, what do you use? #16
As a "decoration"/pen & pencil holder on my desk, I have a cylinder sleeve from a 1979 John Deere 4240. I bought the tractor in 1984, with less than 800 hours on the clock. It had the entire volume of the coolant system in the oil pan when I hauled it home...:O
With under 800 hours use, and NO coolant upkeep in it's 5 years (at that point) the rear-most cylinder liner had 2 holes that looked like someone took a cutting torch and blew very small holes in it, right at the base where it presses into the block. OTHER THAN the coolant being neglected, the tractor was in great condition. Needed a new crankshaft, 2 rods, all bearings, rings, new sleeves, valve train, and oil pump. Cost (at that time) was about $900 under what a new crate engine would have cost.
Check ph level of coolant to get a picture of what condition it's in. Fram makes a diesel coolant system treatment. It comes with litmus test strips and all the info you need to keep your diesel in tip top condition. Deere offered a cooling system upgrade for 400 series 6-cylinders. It is essentially a filtration system. (to remove small rust particles which are part of the problem...) The filters come pre-charged with coolant system treatment. I've since added the filter system to a couple Deere 4-cylinder engines and one 6-banger. (2440, 2640, and 4440)
   / Coolant change, what do you use? #17
I have been wondering all that since I bought mine in '95. Let me know if you find out.
All we know for sure is: MF says, if you change it annually with regular antifreeze, your going to be fine.
Do that, or roll the dice.
If you really want to cover all the bases, you can always use the heavy duty diesel antifreeze, and change it annually. :D
   / Coolant change, what do you use? #18
yep.. the swizzle sticks and addatives are TOO CHEAP to not use them.
soundguy
   / Coolant change, what do you use? #19
Engine design appears to play a critical role. I have a TDI Jetta Wagon. I have never heard of a cavitation issue on a VW. I also have a 7.3L E350. Those engines, particularly the indirect injection ones, have a significant caivitation issue. I even received a letter from Ford reminding me to ensure adequate supplemental coolant additive on my IDI van. My current direct injection van never warranted a letter from Ford. Nevertheless, I religiously maintain my molybdate and nitrate levels in the coolant of that one, just in case. I always wonder if the lower compression level in the direct injection motors made the problem go away.
I've never really done much on my GC2300 other than periodically change the coolant. Never added an SCA. Compared to over 1,000,000 7.3L engines and likely even more VW TDIs sold, the Iseki does not have a lot a owner experience. Has anyone ever heard of cavitation on a small bore engine? My gut says small engines experience less cylinder wall flex and hence less cavitation.
   / Coolant change, what do you use? #20
By no means do I know everything there is to know on the subject, I do know of a few different engine designs/series/ect from a few different brands that were all proned to cavitation and/or electrolysis (sp??). All those were in-line 4 or 6 cylinder, cast iron block, WET SLEEVE engines. In every instance (with the engines I'm familiar with) they ALSO had a history of "dirty castings" (as far as the water jackets). Rust particles played some role in the erosion of the sleeves. As I said, that's with a hand full of engine types.
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
