Conveyor floor / tarp for trailer
   / Conveyor floor / tarp for trailer #1
WinterDeere
Super Star Member
Philadelphia
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
I have need to move large amounts of yard waste (tree trimmings, shrubs with root balls, tens of thousands of walnuts, etc.) from my property to a mulching facility. I have a closed-side landscape trailer (Big Tex TV70) with a 16' x 6' box. I also use this trailer for moving mulch, crushed stone, compost, logs... you name it.
For all but the logs, I'd like to find some heavy tarp-like floor with a pulling bar and ring on one end, that I can lay down in the floor of the trailer before loading it with material. That way, when I reach my destination, I can hook the ring on the end of this tarp to a tractor or loader, and draw the entire bulk of material out of the trailer in one fell-swoop.
I've seen conveyor systems for trucks, trailers, etc. But they're more complex systems which provide their own motive power to withdraw the material, whereas I'm just looking for an extremely heavy tarp (i.e. made from conveyor material) with a draw bar and ring on one end. Can anyone recommend such a product?
Thanks!
   / Conveyor floor / tarp for trailer #2
If you do that, won't the tarp land on the ground under the material being unloaded?
   / Conveyor floor / tarp for trailer #3
Why not: 2000 lb. Capacity Truck Bed Cargo Unloader
The key is to not overload it to the point that the weight overpowers your ability to winch it out. The other key is to have a slick trailer floor. One member here put vinyl flooring down on his trailer bed for that reason.
Yes, but with an FEL, you can simply lift the bucket and the material will roll off. With a pickup truck, you're counting more on speed and inertia, to yank the tarp out from under it. :D
yeah, that's the idea, but I need a 16' long x 6' wide variant, that can handle 5000+ lb. I don't need the winch, I have machinery that can draw it out. Really, something like that material with a draw ring on the end to look to a tractor, tree, or pickup truck.
   / Conveyor floor / tarp for trailer #7
Depending on your debris, etc., this might work.
Get conveyor material 3-4 ft longer than the trailer. Fasten it to the trailer at the rear. Put the tow ring on the front. Load it with the front end going up the front of the trailer. Unload by pulling the ring to the rear, over the top of the debris, rolling the debris off the rear of the trailer, with the conveyor material ending up on top.
Bruce
   / Conveyor floor / tarp for trailer #9
Get a slide in bed liner and cut it to fit your needs. Have a 2x4 bolted to it and attach eye bolts to the 2x4. They are pretty tough and will last for years.
   / Conveyor floor / tarp for trailer #10
May also want to consider the weight of this liner since you may have to move it by hand when placing it on the trailer floor.
Old combine or swather draper head canvas might work if you can find 6 ft wide.
Polaris Ranger (A56859)
Polaris Ranger...
Mini Excavator Hydraulic Auger (A55272)
Mini Excavator...
2014 CATERPILLAR 966K WHEEL LOADER (A52709)
2014 CATERPILLAR...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A56858)
2013 International...
2016 Snorkel S4732 Scissor Lift (A57453)
2016 Snorkel S4732...
49205 (A55788)
49205 (A55788)
