BackRoad
Veteran Member
Picked up a used 100 gallon transfer tank with a 12v pump, which had been used for Unleaded fuel - plan is to use it for diesel.
Drained the Unleaded gas and aired out the tank for a few days.
Put about a gallon of off-road diesel in, rinsed it around well and drained the tank.
Removed the original gas filter and removed the hose and drained the remaining gas from it.
Put it all back together and replaced the filter with a new diesel fuel water/particulate filter.
Only item remaining is picking away at a large - seriously stuck on - reflective "Unleaded Gas Only" decal which is coming off in tiny 1/4 inch pieces.
Kindly interested from the TBN Brain Trust if there is anything else needing to be done before using the tank for diesel???
