Converting manual 3ph to hydraulic
   / Converting manual 3ph to hydraulic #1
cleatus
granbury tx
sears suburban
Anyone converted a manual 3ph to hydraulic or added one to a tractor that came without.
   / Converting manual 3ph to hydraulic #2
This whole tractor has been a low budget job...$400 for everything!!
I wanted to mount the cylinder under the axle with an "L" arrangement but that didn't happen.I need to make a top link that'l go around the cylinder yet...mind you..it ain't done and it sure ain't purdy...
Bob, I had looked at that pic before and had 1/2 thought about adding to the above post " other than Bobodu'' not that what you are doing will not work, but was for something a little different. After reading 18 pages of your project at MBN, of course with a fine sprinkling of humor and some BS, I realize we are a lot a like. We take others so called junk and build useful altercations in metal. /forums/images/graemlins/confused.gif but /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Converting manual 3ph to hydraulic #4
Cleatus....I'm gonna point that post out to Tami....I expect the women will start a support group.LOL
   / Converting manual 3ph to hydraulic #5
Plenty.. Including one that used one of those 12v hyd power units to power a small lift cyl the that turned a rockshaft using a piece of pipe as a seat for the shaft. The rockshaft lifted two fixed upper arms. then they had lift links to lower arms that were fastned to a lower bracket.
I've also seen a similar setup to that on a garden tractor, using a bottle jack as the lick.. and the handle stuck out between the seat and fender for the user to manuall pump the bottle jack up.. an extension was added tot he drop valve so that it could also be reached convieniently.. That one was the neatest looking one.
Soundguy
Thanks Soundguy, saw one on a new consctruction tractor, just had a cylinder laid on side under floor board.
Here's a shot of the manual.
Also a shot of manual blade linckage.
And just an idea of how small the tires are.
   / Converting manual 3ph to hydraulic #10
Cleatus I had one of those that hte handlewas beaten out of so I used a convertibles hydraulic roof pump and an out board motor cylinder. I had one customer mountasmallhydraulic highspeed worm drive motor in his andle with asprocket and chain. bvoth setups worked pretty good on the little tractors. What kind of tires are theose Ditch Witch?
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2012 FORD E-SERIES 11 PASSENGER VAN (A52472)
2012 FORD E-SERIES...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
2016 Nissan Murano SL AWD SUV (A50324)
2016 Nissan Murano...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
