allyolds68
I apologize if this has been covered before by there isn't any option to search "all" keywords so it seems next to impossible to ferret out the handful of useful responses that are probably already on this forum on this subject
I have a late 80's Struck MT3000 with the loader and backhoe attachments. It's got an 18 HP Briggs I/C motor. The drive system is a belt driven through a friction clutch to a Tecumseh (Peerless) 2338B transaxle. It's a 4 speed transaxle with 2nd gear locked out so it has reverse, 1st and 3rd. The 84" belt that drives this system is cumbersome and takes a couple (like 5) seconds to fully disengage. The trans can't be shifted until the belt system stops entirely. With the shroud on its difficult to tell if the belt is still spinning so invariably the trans gets ground once in a while. I just dropped almost $400 to get the trans rebuilt. I should note that I just bought this and the damage was not done by me but I see this as an inherent problem.
Seeing as there is already a hydraulic pump to feed the attachments it would make sense, it seems, to install a hydraulic drive motor with a fixed or variable speed control valve coupled to the trans with a belt or chain drive. I am thinking belt is better because it is a little more forgiving. These transmissions were used for years in the older John Deere tractors (212 & 214 I think) so I am guessing someone has done this. I wish I could tell you the specs on the hydraulic pump but all I know is its part number 36202-104 and it appears from the literature I have with the machine that it may be a YB series pump, possibly from Webster Electric. My research of any of this has turned up next to nothing. I am fairly sure I could call CF Struck and they could sell me a conversion kit but I would kind of like to save a little money and do it myself.
I am not into this machine for much and it seems to be a pretty useful homeowner type piece of equipment so I don't mind sinking a little (like less than $500 if possible) into it. I have got a quite a bit of grading to do (it is also got a dozer blade) so I can built a garage so it's going to get a lot of use this spring.
Thanks,
Mike
Thanks,
Mike
