Converting Belt Drive Trans to Hydraulic Motor
   / Converting Belt Drive Trans to Hydraulic Motor
I just went out and measured it. The drive sprocket is about 1-3/4" and the driven sprocket at the track is about 6". The reduction is about 3.5 to 1. The driven gears runs a track sprocket that's about 10" in diameter These machines literally have to crawl at probably one foot per second in low gear which is about 1/2 mile per hour. I don't have a calculator in front of me but this tells me the drive motors have to turn pretty slowly and require quite a bit of torque
   / Converting Belt Drive Trans to Hydraulic Motor #22
Looks like I'm a year or so late but wondering if this project is completed. Reason is I have an MT 1800 with a peerless transmission (the housing is broken at the axle). I have a ZTR drive (a pair of Eaton #778) from a snapper mower that has promise of being adapted. My plan is to drive each track sprocket utilizing the current braking system. I haven't counted the number of teeth in the sprockets to get the exact reduction but eyeballing it looks to be around 6 to 1 from ZTR to track sprocket. To drive the Eaton drives I was planning on adding a hydraulic pump and motor in lieu of a belt and right angle gearbox. I might be a little shy of horsepower as the mower had a 15 HP Kohler and the 1800 has a 18HP Briggs.
Would appreciate any input as I plan on adding this as a project in progress to the website.
   / Converting Belt Drive Trans to Hydraulic Motor #23
I also have an MT 1800 Struck dozer.
I was thinking of doing the same thing, but a hyd motor for each side.
Look at the torque on those motors and get the highest you can find.
Using 18 HP, you can pump 9 GPM at 3000 psi, or 10.5 GPM at 2500 psi.
To get the 9 GPM from that engine, you need a pump with a displacement of .6 cu in.
You might also look at these ZTR hyd sets.
Looking back at my earlier post, I forgot that I had posted about my dozer.
Surplus Center
   / Converting Belt Drive Trans to Hydraulic Motor #24
Thanks for the response. I already have the ZTRs salvaged from a Snapper mower. It looks like a combination of .5 and .58 Parker motor/pumps from Surplus Center would be a close match to the torque/rpm requirements of the Eaton 778s. Since the existing pump runs a pressure system I'm losing some HP as that runs continuely. As it will be an open system I might be able to use the existing reservoir or maybe add a small heat exchanger. I built a set of tracks for this unit which is posted in the Struck group.
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
