Converting 1 acre old septic leach field. Should I leave it in place or remove it?
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it?
I would not be concerned with it. If anything, bring in topsoil and build the level up.
I'm planning on running the tiller over the top 2" to get rid of the grass. Then bring in a ton of compost and till that in no more than 6" and be done with it. I'll probably use a bedder on the 1025R as well.
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #32
I like your plan.
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #33
I would just pretend it is not even there. Normal gardening / farming activities don’t go that deep.
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #35
I agree X2
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #36
Wondering about the irrigation aspect of the old system, 20" down. How much water would it take to flood system and have water migrate up, and what kind of supply of water is necessary and capacity? Would water supply from a home be enough, or are we talking stream or equivalent?
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #37
How is this field doing since early spring? Just curious if you have left it idle and mowing, or if using the tiller to work it up.
ROME FIRE PLOW (A54756)
ROME FIRE PLOW...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A55788)
2013 Ford F-550...
Future 72in Dual Cylinder Grapple Skid Steer Attachment (A55787)
Future 72in Dual...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
