Converting 1 acre old septic leach field. Should I leave it in place or remove it?
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it?
I would not be concerned with it. If anything, bring in topsoil and build the level up.
I'm planning on running the tiller over the top 2" to get rid of the grass. Then bring in a ton of compost and till that in no more than 6" and be done with it. I'll probably use a bedder on the 1025R as well.
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #32
I like your plan.
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #33
I would just pretend it is not even there. Normal gardening / farming activities don’t go that deep.
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #35
I agree X2
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #36
Wondering about the irrigation aspect of the old system, 20" down. How much water would it take to flood system and have water migrate up, and what kind of supply of water is necessary and capacity? Would water supply from a home be enough, or are we talking stream or equivalent?
   / Converting 1 acre old septic leach field. Should I leave it in place or remove it? #37
How is this field doing since early spring? Just curious if you have left it idle and mowing, or if using the tiller to work it up.
2025 epic golf cart (A55758)
2025 epic golf...
High Lift Ratcheting Off Road Utility Farm Jack (A55787)
High Lift...
2018 John Deere 325G (A47477)
2018 John Deere...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
KUBOTA B26 TRACTOR BACKHOE (A52705)
KUBOTA B26 TRACTOR...
