Front-End Loader Convert to SSQA but keep bucket ears......
   / Convert to SSQA but keep bucket ears...... #1
skytracker
Hale, MI
Ford 3000
Has anyone converted their pin on bucket to the standard SSQA type but not removing the original bucket ears??
I would really appreciate the input if they have.
I have a Ford /New Holland pin on bucket on my Ford that I want to convert but leave the bucket intact to use on another tractor as well>
I was thinking if I made up pin adapters out of DOM steel tubing for the 1 inch pins that fit between the ears and weld them to heavy flat stock
maybe 3/8" x 4" x4" or 2 stepped layers of 5/16", then weld that to the SSQA plate.
Then buy/make adapters for the loader arm side to the QA/ latch bracket that palletforks.com has.
And then get a second set of 1 inch pins.
That way the plate would be removeable to use the bucket elswhere and not extend the connection out too far to the loader.
I want to upgrade to a 4 in 1 bucket but cannot afford to yet. When I do this bucket could stay on the other tractor.
   / Convert to SSQA but keep bucket ears...... #2
Will the SSQA plate fit between the bucket ears? You need 44 inches.
Unfortunately no, good thinking but I had thought of that. I have only 32 3/4" on this 60" bucket.
And this is fairly heavy duty with 3/8" plates for the bucket ears.
Nobody has done this??
I am trying to find an adapter or make one for the bucket side. I think I remember seeing some made by Washburn equipment or something like that.
I will keep searching for the answer.
   / Convert to SSQA but keep bucket ears...... #5
Xfaxman,
Thank you that is the one. I need to make a set of weld on adapters to match the SSQA plate to the bucket ears.
I can probably make from 3" x 3" - 5/16 or 3/8 angle.
And then attach the loader side and I should be good.
2012 GMC Savana 3500 Passenger Van (A55852)
2012 GMC Savana...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
1985 Ford Ltl9000 Tender Truck (A57024)
1985 Ford Ltl9000...
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
2006 JOHN DEERE 650J XLT CRAWLER DOZER (A52707)
2006 JOHN DEERE...
2016 FREIGHTLINER CASCADIA SLEEPER (A57880)
2016 FREIGHTLINER...
