convert single to double acting ram?
/ convert single to double acting ram? #1
Cord
Richfield, Wi
Resident Architect
I have a log splitter project that I was working on some time ago and set aside for the lack of a ram. The splitter has a multi-way head and I'm just not comfortable with a 5" ram. A 5" might work, but I'm not certain it will. So I've been searching for a 6" ram. It'll be slower than I want, but it'll have the power I may need. I recently found one for a good price, but it's off a forklift so it's single acting. Can the second port be added to a single acting ram thus converting it to a double acting ram? When the port is missing, how is the air typically vented? Because this is a splitter application, the ram won't see much pressure on the return stroke, just enough to activate the detent.
/ convert single to double acting ram? #2
First, a 5" bore cylinder would produce almost 10 ton of force at 1000 psi. That's quite a bit of force.
On to the cylinder question. The only definitive answer I could give is that it's probably less time consuming and cheaper to just find a double acting. The ease in converting a single to double depends entirely on the construction of the actual cylinder involved. Single actings can be built with or without pistons and that would be the first determining factor - ie no piston, no double acting. If the cylinder does in fact have a piston, the seal design then becomes an issue. If the retainer isn't set up for more than a wiper, you looking at altering it at the least and may have to make a custom piece. $$$
/ convert single to double acting ram? #3
Don't think I'd try and make a conversion as per reasons already stated.
Have you considered attaching a spring or smaller inexpensive ram for the return?
Egon
/ convert single to double acting ram? #4
I have a splitter with a 4" cylinder running on 2200psi and it will shear a 10" log in half sideways. I have never had it stall while splitting a log. What's with the need for a 6" cylinder?
I agree with the above about converting a single acting cylinder.
/ convert single to double acting ram? #5
With the right pump a 4" works just fine.
I have a sneaking suspicion that a forklift ran is a cup seal affair and these aren't really meant for that type of pressure.Forklifts generally have chain over pulleys that change the mechanical advantage.
My neighbor has a 5" ram on his splitter that he runs off an Oliver 1850....no log has ever won.
/ convert single to double acting ram? #6
Depending on the design of the end cap & the material it's made of, you could possibly drill & tap a hole to accept a second hydraulic line. how about some pics? What is the shaft diameter of the piston?
/ convert single to double acting ram? #7
Before going to that 6" you better do your homework cause you can bend an awful lot of steel with a 5". What is the max pressure your pump will produce? What kind of wood are you spliting?
I don't have the ram yet, but I found a junk yard that had a bunch of old forklifts. Thought maybe one of their rams might work for me.
The splitter has a 7 way head on it. Not the traditional two way. You feed the log in and it cleaves it in half. The one half is then cleaved 6 more times. All of this is done in one pass. I was planning on using a 28gpm two stage pump. The pump is capable of 3,000psi sustained. A 6" ram won't give the inches per minute I'd like, but with the splitter design it will only take two pushes to finish a log. The splitter that I designed this off of used a 5" ram. I figured that my head design wasn't as efficient as theirs. My head is also welded on where as their design allowed the head to be removed and replaced with a two way wedge for a really curly piece of wood. For these reasons I was thinking that I should go with a 6". The frame for the splitter is a 8"x12"x5/16" rectangular tube.
/ convert single to double acting ram? #9
Yes, you can convert them. I have done it. Some of the 3-pt concrete mixers come with crappy single-acting cylinders. If your SA cylinder is extension only, you may not have good rod seals cuz the piston seal does all the sealing you need. I found my SA cylinder worked fine with only welding on an adapter and making sure the air bleed on the retraction side was sealed.
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
THIS WILL BE A TIMED ONLINE AUCTION! (A65640)
THIS WILL BE A...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
