Rake Convert Rake to Rubber Blade??
/ Convert Rake to Rubber Blade?? #1
Tim_in_NH
Southern New Hampshire
I was toying with the idea of adding a piece of horse mat to my rake to use as a snow blade for next winter. Has anyone tried such a thing or think of any reason why it won't work out? I thought I could just use a few "U" bolts or something along those lines to secure it. I would use a piece of mat about 16" so it will curl up the tines a bit. It would only be for 6" or less of snow as I would be using a 3pt snow blower for heavier snowfalls. Sounds good to me, in theory anyway! /forums/images/graemlins/laugh.gif
/ Convert Rake to Rubber Blade?? #2
Do you have the Woods Estate rake with wheels? Your idea sounds good to me - except when I think of how many u-bolts you'd need - I guess it would be cut and try?
/ Convert Rake to Rubber Blade?? #3
Instead of u bolts use 2 pieces of strap iron and bolt thru both of them w/ mat and tines between.
could even put 1 set at top and 1 set lower to let mat flex to tine radius.
Yes, it's a Wood Estate rake. (See photo) Model number is LRC60 and I was charged $695 for it. It works great!
/ Convert Rake to Rubber Blade?? #5
Tim,
Have you tried it without the gauge wheels?? Do the gauge wheels make a big difference when finish grading (less humps,etc.)??
DaveL
I did try it without the wheels. It seems to dig too deep and was very hard to get a nice level finish. I'll be spreading 20 yards of loam in a few weeks with it. With the wheels set a bit lower then now, it should do a great job.
/ Convert Rake to Rubber Blade?? #7
Looking at the shape of the tines, it appears snow would accumulate and push up on the rake, even if canted hard to one side..................chim
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A61572)
2023 John Deere...
