Convert Kohler Terramite T7 from Propane to Gas
   / Convert Kohler Terramite T7 from Propane to Gas #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I have a Kohler powered T7 which came from the factory with the propane fuel setup. I had a little problem with it freezing up yesterday and, since I don't understand anything about the propane components (regulator thingy, mixer thingy) I have decided to just make my life simpler and convert it to gas. It has a pristine, never used, fuel tank and filler, so that should be easy, but I'm wondering if the carburetor on this thing if different than what comes on the gas models. If not it's not a big expense to replace it with something Chinese these days, but I would like to see if I can preserve the existing choke and throttle linkage setup to keep things simple.
Has anybody done something like this or who can provide simple guidance about what I'm up against?
   / Convert Kohler Terramite T7 from Propane to Gas #2
If the engine came with a built-in fuel tank it most likely is a duel fuel engine. Look up the model and serial numbers for engine specs.
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
NEW Landhero Mini Excavator (A59000)
NEW Landhero Mini...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
