Convert Kohler Terramite T7 from Propane to Gas
   / Convert Kohler Terramite T7 from Propane to Gas #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I have a Kohler powered T7 which came from the factory with the propane fuel setup. I had a little problem with it freezing up yesterday and, since I don't understand anything about the propane components (regulator thingy, mixer thingy) I have decided to just make my life simpler and convert it to gas. It has a pristine, never used, fuel tank and filler, so that should be easy, but I'm wondering if the carburetor on this thing if different than what comes on the gas models. If not it's not a big expense to replace it with something Chinese these days, but I would like to see if I can preserve the existing choke and throttle linkage setup to keep things simple.
Has anybody done something like this or who can provide simple guidance about what I'm up against?
   / Convert Kohler Terramite T7 from Propane to Gas #2
If the engine came with a built-in fuel tank it most likely is a duel fuel engine. Look up the model and serial numbers for engine specs.
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
7021 (A55851)
7021 (A55851)
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
Hose Reel (A55758)
Hose Reel (A55758)
