convert JD loader to SSQA
/ convert JD loader to SSQA #1
wango tango
Peoria IL
Looking for opinions on the best way to convert my 400cx JD loader with the JD quick-attach system over to a SSQA. I know there are adapter plates, but I've seen wild price variations and not sure how strong the cheaper ones are.
Anyone done this, and what was the best bang/buck approach?
/ convert JD loader to SSQA #2
The best way is to go to JD and get the parts, but what is not available in the JDQA system that you want to use?
http://www.greenfarmparts.com/John-Deere-SKID-STEER-ATTACHMNT-CARRIE-BW15244-p/bw15244.htm
John Deere Holder BW15244
SKID STEER CARRIER
Cart key PART NO. PART NAME QTY SERIAL NO. 400X 400CX REMARKS
1 34M7251 Spring Pin 1 X X 10 X 55 mm
2 34M7216 Spring Pin 2 X X 6 X 35 mm
3 AW32725 Holder 1 X X RH
AW32723 Holder 1 X X LH
4 W50737 Weld Pin 3 X X
5 KV14518 Washer 3 X X
6 KV15409 Compression Spring 2 X X
7 KV15906 Handle 1 X X RH
KV15907 Handle 1 X X LH
8 KV15968 Guide 1 X X
9 KV18477 Strap 1 X X
10 KV18988 Pawl 1 X X RH
KV18987 Pawl 1 X X LH
11 W50194 Pin 2 X X
12 BW15244 Skid Steer Loader 1 X X COMPLETE GOODS/SHIP BUNDLE
Just kind of want SSQA as I'm buying a grapple, pallet forks, 4 in 1 bucket, and such.
I'll check out the JD option. I'd prefer that honestly!
/ convert JD loader to SSQA #4
Just bought a 4520 and has the 400X with JD loader. Already have a SS and a bunch of attachments with SSQA.
KennyD - If I understand the parts diagram correctly, #12 the BW15244 bundle includes everything I need (#1-11), right?
Is that all that is needed to convert? other than labor LOL
I'd rather spend the comparable $ to convert rather than adding on an adapter b/c I'll never use the JD and don't want to lose lift capacity for nothing.
Thanks!
/ convert JD loader to SSQA #5
Is that all that is needed to convert? other than labor AND MONEY LOL
I believe that to be correct JFon. See my edit in RED
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
PALLET OF JOHN DEERE WEIGHTS (A64278)
PALLET OF JOHN...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
