Convert Field Mower Cutter to 3Pt?
   / Convert Field Mower Cutter to 3Pt? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Thinking ahead a bit since I haven't gotten very deep into SCUT shopping yet. If I do, I won't have much available to buy extras and I don't think the small machines I'm considering will handle a larger rotary cutter. BUT, the brain commenced to wonderin' ....
I have one of these:
The front section separates and you have this:
... which is basically a 3' rotary cutter which will take down most of what gets in its way. Under that gray hood is a large pulley that connects by belt to the drive pulley on the engine section.
Aside from the obvious issues of wheels and a 3Pt mounting frame which can be dealt with, is it possible to add a mechanism to run it off a PTO? If so, how and at what cost? It would have to be something that could be easily removed and converted back to the original self-propelled unit.
   / Convert Field Mower Cutter to 3Pt? #2
How many HP is the engine on it now? How many PTO HP will you likely have?
Probability is you'll spend a lot of money, mount it, and the first time you actually cut with it the tractor will rip it apart.
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2005 TRANSCRAFT 48 X 102 FLATBED (A52472)
2005 TRANSCRAFT 48...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
