Convert Field Mower Cutter to 3Pt?
   / Convert Field Mower Cutter to 3Pt? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Thinking ahead a bit since I haven't gotten very deep into SCUT shopping yet. If I do, I won't have much available to buy extras and I don't think the small machines I'm considering will handle a larger rotary cutter. BUT, the brain commenced to wonderin' ....
I have one of these:
The front section separates and you have this:
... which is basically a 3' rotary cutter which will take down most of what gets in its way. Under that gray hood is a large pulley that connects by belt to the drive pulley on the engine section.
Aside from the obvious issues of wheels and a 3Pt mounting frame which can be dealt with, is it possible to add a mechanism to run it off a PTO? If so, how and at what cost? It would have to be something that could be easily removed and converted back to the original self-propelled unit.
   / Convert Field Mower Cutter to 3Pt? #2
How many HP is the engine on it now? How many PTO HP will you likely have?
Probability is you'll spend a lot of money, mount it, and the first time you actually cut with it the tractor will rip it apart.
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
John Deere 5100M (A53317)
John Deere 5100M...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2020 CATERPILLAR 259D3 SKID STEER (A52707)
2020 CATERPILLAR...
