Convert atv sprayer to boomless?
/ Convert atv sprayer to boomless? #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
I have a atv mounted sprayer that I use for poison ivy control and spraying for powderpost. http://www.northerntool.com/shop/tools/product_200578567_200578567 My local ag supply store is suggesting that I switch to liquid weed control for the lawn instead of using a weed-n-feed type product. I have a 3 acre lawn and he's saying the switch point is 1-1.5 acres. To that effect I'm looking to convert my sprayer. I know a lot of people have been going boomless, but I can also see the advantage to having a boom. Because this is a conversion, i'm tempted by the boomless design. My sprayer is 5.5gpm and I have it set to 60psi. Should I go with one nozzle or two? I was thinking of a Boominator 1200 PS, although my pump probably could support a larger 1400 PL.
  • Boominator tip.pdf
/ Convert atv sprayer to boomless? #2
I spray about 5 acres with a boom I made up and added to a tow behind sprayer that now sits I the FEL. The boom is 5.5' with 4 nozzles and covers about 8' per pass, which is plenty wide for my use. I know you are specifically asking about boomless sprayers, but it's hard to beat the precision and spray pattern of standard sprayer nozzles. JMHO.
/ Convert atv sprayer to boomless? #3
There are advantages to both type sprayers.
I have a 12' boom sprayer on the back of my JD gator. I spray several hundred acres a year with it.
I also have a boomless tip that I use to spray my deer food plots which are about 30 acres a year.
With a boom sprayer, you have more accuracy and less chance for getting product off target, and less chance for overlap, and they cost more and need more cleaning of spray tips.
With a boomless sprayer, you have less chance of damaging your sprayer by hitting it on a fence post or hooking it on a tree or something, but you have a greater chance of spraying something that you don't want to spray. And you can use them in taller grass (such as food plots).
Sounds like I really want a boom sprayer then. Ok. Anybody know of a retrofit kit? What nozzles are on your rigs?
/ Convert atv sprayer to boomless? #5
I'm sure you can find a boom kit at lots of places such as Tractor Supply or others. I have 8004 tips on my boom. This means they spray at an 80 degree angle and put out about 0.4 gallons per minute. These tips need to be about 30" above ground in order to get the correct overlap.
You could also use 110 degree tips, which need to be about 20" above ground.
Generally, you want more gallons per acre. You get better coverage with more volume. But you don't want to put too much, because you will just be filling your tank too often.
/ Convert atv sprayer to boomless? #6
I like the spring loaded, folding, boom on my Fimco sprayer. It's 10' wide, and the booms fold in if I clip a tree of post.
/ Convert atv sprayer to boomless? #7
I prefer a boom sprayer since it is more accurate and the operator has better control over
where the chemical is being applied. I have 8003 tips in my sprayer. More pressure plus
smaller tips equals smaller droplets which means more potential drift. The height and spacing
of your spray tips is important and the boom height should be adjustable to spray a pattern
for your target zone. I have a Tjet catalog and it explains all their products and how to set
up a sprayer system. In farming areas there should be a commercial chemical business and
they can supply parts to set up a spray boom. A dry boom means the fluid is distributed by
hose and supported by a metal frame. A wet boom means the frame carries the fluid inside
the frame structure.
/ Convert atv sprayer to boomless? #8
pics below of my makeshift sprayer setup, ready to roll with some Trimec to bludgeon the spring weeds.
it's not quite a completely "home built" system. i started off using a generic FIMCO setup (w/ 25 gallon tank), which came stock with a hand sprayer (wand) (see pics below). the FIMCO tank was simply set on my carryall. the pump itself is powered by the 12Vdc accessory outlet below the operator seat; this feature is stock on the BX series. i added more pressure hose, so my wife could slowly drive the tractor and i would walk around behind the rig and dispense herbicide using the sprayer wand. i should mention that the area to be treated is just north of an acre. basically with this setup i had a 25 gallon capacity hand sprayer, and i was trying to treat an acre+ of turfgrass twice a year. this "hand spray" approach was sorta effective on the weeds but a general pain in the ***, plus the uniformity of application is always in question. maybe the best feature was that with the handheld wand you can get fairly close to ornamentals and such.
i started looking around for bits and pieces to convert the hand system to a nozzle system. in principle this means finding a boom assembly that has the coverage desired AND has a flow rate (at a given pressure) which the pump can handle. note that this conversion is not exactly straightforward because the pump setup used for a hand system (demand type: pressure low turn-on / high turn-off) is not the same as used for a spray system (constant pressure with bleed recirculation). in my case it worked out ok that i had a pressure turn-on/turn-off pump arrangement, it took some experimentation initially but the system runs at a nice even 30psi during spray operation. note: too little pressure and you will get sputtering; too much pressure and you will atomize the herbicide-laden liquid into a fine cloud which will blow all over the place.
my carry-all deck does not come up high enough for the Teejet nozzles, which have a specified 18" height above terrain for proper spray coverage. i was going to carpenter-up some sort of base for the tank to sit on, which in turn would be placed on the carry-all, but then i got to thinking i could just use the ballast box as the tank carrier. a pair of carefully cut and mounted scrap 2x4's allow the tank to "seat" in the top of the empty ballast box, and once it's filled with water and herbicide the tank is not going anywhere.
i stumbled around in the sprayer aisle at Tractor Supply for a while and bought some more pressure hose, fittings, and an poly 90 degree shutoff valve. the pressure output of the tank, instead of going to the hand wand, is carried up to near the operator station, where the control valve is located, and then back to the spray heads. (note: try to keep the piped "distance" to the spray jets symmetrical, otherwise you get pressure imbalance).
so, to prepare for spraying, you fill the tank 2/3rds with water, put the herbicide in, and then fill the remaining third. during all this you run the pressure pump in "recirculate mode", which draws in liquid from the bottom of the tank and pumps it right back into the top of the tank (this is a stock function of the FIMCO pump manifold setup). after about 10 minutes of recirculating you are ready to roll.
position the tractor where you want to start, twist the control valve 90 degrees to start herbicide flow, and get moving ASAP. do not stop the tractor without first turning the control valve off, or you will deposit A LOT of herbicide in one place.
i want to point out a few things:
1) before your first spray job, it is first necessary to determine how much solution you are applying at a given speed. this is best done using a tank full of water and a known distance (i measured using GPS). fill the tank right to the brim, and close the top. make a run. using a kitchen measuring cup, refill the tank right to the brim. now figure out, at a given tractor speed (RPM and range), how much fluid is going out, and therefore the application rate. the spray head folks, Teejet in this case, provide tables for every one of their nozzles, in terms of flow rate (GPM) vs PSI. don't forget to multiply times the number of nozzles.
2) selective herbicides for turfgrass (such as 2,4-D) work by attacking biological aspects of annual and perennial weeds which differ from perennial turfgrass. however, these very same herbicides can and will absolutely demolish plants that are not weeds -- such as tomatoes or lettuce or roses or myrtle or whatever expensive thing your wife just planted. so when spraying in a residential environment you have to be extraordinarily careful about where the spray is applied and just as importantly where the wind is carrying it. for this reason, calm days and "just enough" system pressure are critical aspects. when i first used my makeshift sprayer i tested coverage in the driveway using straight water, and then used a piece of PVC conduit as a "guide" for my first go around. this guide would prevent my wife from subsequently killing me for killing all of her flowers. yes, it looked ghetto as **** but i'm still alive today.
3) don't spray when it's very hot. the turfgrass is already under stress during these conditions. even though the herbicide is "selective" you can still kill huge swaths of turfgrass by applying an otherwise "safe" herbicide when it is 100'F outside.
4) you need a TON more water to apply fertilizer vs herbicide. so much more that it makes it impractical for me. i apply granular fertilizer (using a broadcast spreader) and spray for weeds (using my makeshift setup). this is the easiest approach.
ps
here is the FIMCO sprayer i started life with. 5 years in the pump and rest of the bits are still going strong.
Spot Sprayer, 25 Gallon Sprayer, Sprayer, Fimco Sprayer | Agri Supply, 32996
also see
Agricultural Sprayers, Backpack Sprayer | Agri Supply ATV Sprayer
and
Standard Trailer Sprayer-Two Nozzle Trailer Sprayer | Agri Supply #32995
wrooster
/ Convert atv sprayer to boomless? #9
I used a boom, still do at the farm but around the house(5 acres) I use this one. http://www.northerntool.com/shop/tools/product_200578572_200578572
On the back of a 4 wheeler. The broadcast sprayer will do about 16' at the height of my nozzle and I don't have to worry about hitting anything with it.
They sell just the nozzle and hanger but seems kind of expensive when the whole setup is about $150 when on sale and using one of the discount coupons they send out every month.
NorthStar Single Nozzle Broadcast Lance | Sprayer Boom Broadcast Kits| Northern Tool + Equipment
/ Convert atv sprayer to boomless? #10
I bought a boom less one from Northern and made a thing to hook it on my 3 point. The boom less works good enough, the other kind would work better.1466985088657.jpg I don't know why my picture rotated when I uploaded it.
/ Convert atv sprayer to boomless? #11
I started out with a 200 gallon boomless sprayer run by the tractor pto and mounted on the 3 point hitch. Seemed like a good idea at the time, as I only had about 25-30 acres to spray. After using it one or two times, I got the boom kit for it, 21' I think, and converted it. In the process, I left the boomless nozzle in place and plumbed in valves so I could select either boom or boomless. I used the boom in larger open areas and in areas with trees and such, I could fold up the boom and switch to the boomless nozzle. This system worked very well for me. One added benefit I noticed immediately was that you get far less spray on you, especially if there's a little breeze. Using the boom puts the spray exactly where it needs to go, rather than spraying up in the air and hoping for the best. You certainly don't want something like 2,4-D or grazon drifting around the neighborhood.
One other thought--I think that 60 PSI is way too much pressure. Probably causes a lot of mist as opposed to droplet output.
/ Convert atv sprayer to boomless? #12
I like the boom personally. I bought the county line 30 gallon trailer sprayer on sale for $220 and made my own carry all out of spare wood I had laying around the garage. Works great for my needs.
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
43018CFL (A59228)
43018CFL (A59228)
