Rake Controling gravel spill from Bush Hog rake
   / Controling gravel spill from Bush Hog rake #1
loy44
Peoria IL
Ford 3000 Diesel
I use my Bush Hog MLR 84" rake on my gravel driveway every spring. When I have the rake angled and pitched to create a crown, I get spill out of gravel off the leading edge of the rake. This causes gravel to spill into the grass. I believe I have seen a metal plate that is attached to the first tine to help eliminate this. However, I have not been successful finding a thread describing it or name for it. Any help would be appreciated. Thanks
   / Controling gravel spill from Bush Hog rake #2
loy, I have the same rake, equipped with gauge wheels. Also, I have it fully angled to create a crown. Spillage to the side is minimum because; when I make my first pass, I go beyond the edge of the gravel, into where gravel meets grass. This puts a bit of vegetation into the road, but after I make another pass, the small amount of grass, mixed with gravel; gets disbursed, and dried out. When it rehydrates over time, I believe the plant juices help to solidify some of the gravel. Just my experience on my road.
   / Controling gravel spill from Bush Hog rake #3
I try to stay away from the edge if it is in good shape so it has a cleaner look. You could try angling the rake more and going slower on the 1st pass along the edge.
   / Controling gravel spill from Bush Hog rake #4
I think the side plate you were seeing was part of a inside drop down blade that York used to have as an option.
Regards,
Chris
Gentlemen,Thanks for the input.
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52709)
2003 LEEBOY L150...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
CHALLENGER MT575D (A58214)
CHALLENGER MT575D...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
EZ-GO golf cart (A56859)
EZ-GO golf cart...
