Rake Controling gravel spill from Bush Hog rake
   / Controling gravel spill from Bush Hog rake #1
loy44
Peoria IL
Ford 3000 Diesel
I use my Bush Hog MLR 84" rake on my gravel driveway every spring. When I have the rake angled and pitched to create a crown, I get spill out of gravel off the leading edge of the rake. This causes gravel to spill into the grass. I believe I have seen a metal plate that is attached to the first tine to help eliminate this. However, I have not been successful finding a thread describing it or name for it. Any help would be appreciated. Thanks
   / Controling gravel spill from Bush Hog rake #2
loy, I have the same rake, equipped with gauge wheels. Also, I have it fully angled to create a crown. Spillage to the side is minimum because; when I make my first pass, I go beyond the edge of the gravel, into where gravel meets grass. This puts a bit of vegetation into the road, but after I make another pass, the small amount of grass, mixed with gravel; gets disbursed, and dried out. When it rehydrates over time, I believe the plant juices help to solidify some of the gravel. Just my experience on my road.
   / Controling gravel spill from Bush Hog rake #3
I try to stay away from the edge if it is in good shape so it has a cleaner look. You could try angling the rake more and going slower on the 1st pass along the edge.
   / Controling gravel spill from Bush Hog rake #4
I think the side plate you were seeing was part of a inside drop down blade that York used to have as an option.
Regards,
Chris
Gentlemen,Thanks for the input.
2014 TRAIL KING INDUSTRIES TRIAXLE RGN HG SERIES W/STINGER (A55745)
2014 TRAIL KING...
Ford Tractor (A50120)
2018 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2018 WACKER NEUSON...
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
