Control valve
/ Control valve #1
geomass
Clinton Corners, NY
BX25
I removed my FEL and added a front snow plow. I don't understand hydraulic terminology so I'm confuzzeled as to what kind of control valve I need to install. All I want to happen is for the plow to move left and right as needed.
/ Control valve #2
If removing your FEL has left your valve behind (it does on my tractor) then you have a valve, just plumb hoses to the cylinder. Otherwise you need a simple D/A valve.
/ Control valve #3
You'll need to raise and lower the plow too right?
Your loader should come off like this video shows, notice the joystick valve stays with the tractor so you'd hook your plow to the couplers just like the loader was hooked up, this will give you up/down and left/right control of your plow blade.
Kubota BX-Series Loader Removal - YouTube
2010 FREIGHTLINER M2 BUCKET TRUCK (A65643)
2010 FREIGHTLINER...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
CFG Industrial MX15RX (A64127)
CFG Industrial...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
