Control valve
/ Control valve #1
geomass
Clinton Corners, NY
BX25
I removed my FEL and added a front snow plow. I don't understand hydraulic terminology so I'm confuzzeled as to what kind of control valve I need to install. All I want to happen is for the plow to move left and right as needed.
/ Control valve #2
If removing your FEL has left your valve behind (it does on my tractor) then you have a valve, just plumb hoses to the cylinder. Otherwise you need a simple D/A valve.
/ Control valve #3
You'll need to raise and lower the plow too right?
Your loader should come off like this video shows, notice the joystick valve stays with the tractor so you'd hook your plow to the couplers just like the loader was hooked up, this will give you up/down and left/right control of your plow blade.
Kubota BX-Series Loader Removal - YouTube
Kioti LK3054 Tractor (A66285)
Kioti LK3054...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
Grizzly Bear Statue (A65583)
Grizzly Bear...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
